Topic "Error on WinSCP 3.5.0 startup on W95"
Wolfgang_
When I start winscp350 on my computer (with Windows 95 installed), I always get an error-window:
Title: Error
Text: Error reading LogImages->Bitmap: Failed to read ImageList data from stream
After I click on the OK button the program is closed.
As far as I have tested, nothing changes when I install the program or just copy the executeable.
As far as I have tested, nothing changes when I use the intl version or not.
I also tried winscp330 and almost got the same behaviour. The only difference is:
After the first error-window, i get two others:
Title1: WINSCP330.EXE
Text1: Assertion failed: AConfiguration, file D:\Martin\Projekty\WinSCP2\core\Terminal.cpp, line 1227
Title2: WINSCP330.EXE
Text2: Abnormal program termination
I did not try winscp355beta.
I tried putty and psftp and they both work.
I tried winscp350 on another W95 computer and it works.
I googled for the errormessage and only got two hits:
https://winscp.net/eng/docs/history
and its translation
There seems to be one relevant entry in that history file:
Version 2.0 beta (#101) December 2nd 2002
* Bug "Error reading LogImages->Bitmap: Failed to read ImageList data from stream" on Windows 95/98/ME is fixed.
This is exactly my errormessage. Is this bug back in 3.5.0 ? What can I do to avoid or fix it ?
Thanks for your Help,
Wolfgang Koebler
The error mentioned in the history log occured ALWAYS on all pre-2k versions of Windows. As you can run WinSCP on other W95 computer, then it is not the same.
Do you have any translations installed? If you do remote them and try again.
Unfortunatelly I have no other clue for you Sad I do not have W95 anymore.
