Topic "Connecting to z/OS to download "dataset""
ajdk
Hi (Martin)
I am connecting to an old IBM Mainframe running z/OS (220-TFTPD111 IBM FTP CS V1R12 at DKCSCD11).
I read bug #49, but actually I am very close to downloading the dataset that I need. When I use WinSCP through scripting I can connect fine, but I can only navigate to root, not the directory that I need. z/OS expects me to do a "cd 'FOLDER'" but WinSCP is not too happy about that. The build-in ftp client in windows can do this and so can many other clients, but we want to use WinSCP for different reasons.
I suspect that if I can do the "cd 'FOLDER'" then I will be able to download the dataset with mget (get is not supported), but I am not 100% sure. I would like to work with you on getting this to work and I will donate, I would just like to make sure that this is not either solved or something you do not wish to support.
ajdk
prikryl wrote:
I have sent you an e-mail.
