Topic "WinSCP, SSIS and SQL Job"
jhong
I have the the executing of WinSCP as a Execute Process task in my SSIS project. Works perfectly as I have the WinSCP executable executing commands from a script file. Again works perfectly. However when I run the SSIS package from a SQL job I get the below error. Has anyone experienced this before or know what the issue is? Thanks in advance.
Description: In Executing "C:\Program Files (x86)\WinSCP\WinSCP.exe" "/script=D:\Success_Factors\SCP_Script\myscript.txt" at "", The process exit code was "1" while the expected was "0". End Error DTExec: The package execution returned DTSER_FAILURE (1). Started: 5:00:02 AM Finished: 5:00:05 AM Elapsed: 2.746 seconds. The package execution failed. The step failed.
jhong
Okay per this FAQ http://winscp.net/eng/docs/faq_scheduler
I changed the configuration storage, exported .ini to WinSCP folder and it worked.
Hayden
Thank you ... It worked for me. Smile
twee
I still couldn't get it work please help.
Package works fine manually but failed in job scheduling with error The process exit code was "1" while the expected was "0"
So how do you export to INI file?
Thanks in advance.
TN
Please read documentation:
http://winscp.net/eng/docs/config#export
If that does not help, come back.
