Topic "WinSCP returns exit code 1 when no apparent errors"
stevyrino
Hello .... am using Server 2003 R2 with WinSCP 4.3.6 and .Net Automation in C#.
Am getting ExitCode = 1 on successful transer. No apparent errors in output or log.
These are attached.
relevant .net code:
winscp = new System.Diagnostics.Process();
winscp.StartInfo.FileName = "winscp.com";
winscp.StartInfo.Arguments = "/log=\"" + logname + "\"";
winscp.StartInfo.UseShellExecute = false;
winscp.StartInfo.RedirectStandardInput = true;
winscp.StartInfo.RedirectStandardOutput = true;
winscp.StartInfo.CreateNoWindow = true;
winscp.Start();
winscp.StandardInput.WriteLine("option batch abort");
winscp.StandardInput.WriteLine("option confirm off");
winscp.StandardInput.WriteLine("open sftp://IBD:xxxxxx@ftp.bcliquor.com:22 -hostkey=\"ssh-dss 2048 82:a3:23:ef:81:7f:6e:f9:d9:95:10:f9:a7:d4:b1:ef\"");
winscp.StandardInput.WriteLine("cd Incoming");
winscp.StandardInput.WriteLine("put " + "\"" + batchFilePath + "\"");
winscp.StandardInput.Close();
// Collect all output
string output = winscp.StandardOutput.ReadToEnd();
// Wait until WinSCP finishes
winscp.WaitForExit();
int winscpExitCode = winscp.ExitCode;
winscp.Close();
Any help would be greatly appreciated.
regards
srdux@yahoo.com
sftp20120202.log (6.41 KB) [Download]
Description: /log= result
output20120202.txt (744 Bytes) [Download]
Description: result from winscp.StandardOutput.ReadToEnd()
andys
I have the same issue where my .NET code works fine and files are copied fine with no errors being logged but .NET is returning an exit code of 1
The stack trace is showing
MainModule = 'winscp.MainModule' threw an exception of type 'System.ComponentModel.Win32Exception'
base {System.Runtime.InteropServices.ExternalException} = {"Access is denied"}
I cannot see where the 'Access Denied' is being generated from as I am using accounts with full privileges on both source and destination systems
The winscp log shows a status code of 0
2012-02-08 10:45:59.414 Status code: 0
. 2012-02-08 10:45:59.414 Closing connection.
. 2012-02-08 10:45:59.414 Sending special code: 12
. 2012-02-08 10:45:59.414 Sent EOF message
Any help appreciated
These are attached.
I have sent you an email.
http://winscp.net/tracker/show_bug.cgi?id=794
Popillard
http://winscp.net/tracker/show_bug.cgi?id=794#c4
It will be released in few days.
harsha
WinScp is not moving files into ftp and I am getting below error.
MainModule 'winscp.MainModule' threw an exception of type 'System.ComponentModel.Win32Exception' System.Diagnostics.ProcessModule {System.ComponentModel.Win32Exception}
Please help.
We do not know what your winscp.MainModule is. You should also start your own thread. I do not see any relation to this one.
