Topic "XML Logging not working"
muehlc
I am running a WinSCP script through an SSIS task, and need to have the results of that script logged in XML format. I have enabled logging, but the results in my log are always in the session log format, never in XML. I have not been able to find anywhere in the documentation (and believe me, I have looked long and hard) how to specify that I want the output in XML format. My log file does have the .xml extension, but I am at a loss as to what else I need to do to make the contents of the log file be written in XML format. I am using v4.1.8 (build 415). If anyone can tell me what I'm doing wrong, I'd greatly appreciate it.
TimU
I believe XML Logging was only introduced in the v5.x beta versions.
It is available in 4.x too. But definitelly was not in 4.1.8 yet. Please upgrade.
muehlc
I do love an easy solution to my problems. Works perfectly after upgrade. Thanks!
TimU
prikryl wrote:
It is available in 4.x too.[...]
Really? I'm sure I tried it with the latest 4.x version last week, and it didn't produce an XML log at all.
Tim
Before 5.x XML logging was enabled by: /log=filename.XML
http://winscp.net/eng/docs/commandline#session
TimU
Ahhh, I see now. Very good! Smile
