Topic "WinSCP.dll"
RTD
I am using C# and would like to automate the transfer of files instaed of using scripts as recomended in the documentation but an unable to loacte the file on the site to download.
Please can you tell me where I can download this DLL.
The WinSCP .NET assembly will be released with the 5.0.6 beta in few weeks.
Hashem
Will the .NET assembly enable use of WinSCP's awesome remote file browsing capabilities?!
That's all I need. I need the user to be able to brows the remote files to give input file names for an SSH command. I have the SSH part working, but the file browsing part is tricky.
Would it be possible for me to get access to a pre-pre-release? Smile
In any case, you guys rock! That's for all the effort.
Do you mean this?
http://winscp.net/eng/docs/library_session_listdirectory
Email me.
Gomez
prikryl wrote:
Do you mean this?
Email me.
Hi.
While looking around for a COM-component to transfer files with SFTP i have found that the WINSCP.dll would perfectly fit my needs. Like Hashem i would like to get an pre-pre release of the DLL to test the ability for using it in my environment.
WinSCP 5.0.6 beta, including the .NET assembly has been released already.
