bug report for 2 files with the same name (up to the case)
cb
Under my Linux directory,
I have 2 files : article.ps and Article.ps (not the same)
(they have the same time of modification, but not the same size)
Under my windows directory,
I have just 1 file : article.ps
when I try to synchronize these two directories (in any mode : both, local, remote)
nothing happens, winscp is just ignoring the file Article.ps, while it should copy (or delete) it ! ;-)
Best regards
Re: bug report for 2 files with the same name (up to the case)
I should add a related bug.
In my Linux directory, I have file toto.ps and Toto.ps
(not same size, not same dates)
In my windows, I have only the file toto.ps
When I synchronize, it will suggest to copy Toto.ps (I accept this suggestion).
However, if I checked the synchronization again, it didnt copy Toto.ps
(I guess it copied toto.ps).
Best regards
PS: In the faq/help, I found this :
https://winscp.net/eng/docs/ui_transfer_custom#filename_modification
but it doesnt seem to solve these 2 bugs.
Hm, I'll think about best solution.
