Topic "I cannot download large files"
Boris Berdichevski
I want to download a large file (11,247 KB) and transfer failed: Server unexpectly closed network connection. Tryed on versions 4.3.3, 4.3.6, 5.0.5
Can you try 5.0.5 with disabled session option Optimize connection buffer size?
http://winscp.net/eng/docs/ui_login_connection
jOkEr
the only solution we have found - try to use version 3.8.2 build 330 - IT WORKS.
But the folowing version do not work
WinSCP Version 4.3.3 (Build 1340) (OS 5.1.2600 Service Pack 3)
the version before also do not work
keepalives
The error: Server unexpectedly closed network connection
Copying file 'syslog_info' fatally failed.
Copying files from remote side failed.
The process starts but ends with 6M - 11Megabytes of 47M file tranfer.
Comparing log files:
WinSCP Version 3.8.2 (Build 330) (OS 5.1.2600 Service Pack 3)
. 2012-02-16 12:11:03.933 Transfer Protocol: SFTP (SCP)
. 2012-02-16 12:11:03.933 SSH protocol version: 2; Compression: No
. 2012-02-16 12:11:03.933 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2012-02-16 12:11:03.933 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2012-02-16 12:11:03.933 Ping type: N, Ping interval: 30 sec; Timeout: 15 sec
. 2012-02-16 12:11:03.933 SSH Bugs: -,-,-,-,-,-,-,-
. 2012-02-16 12:11:03.933 SFTP Bugs: -,-,-
. 2012-02-16 12:11:03.933 Proxy: none
. 2012-02-16 12:11:03.933 Return code variable: Autodetect; Lookup user groups: Yes
. 2012-02-16 12:11:03.933 Shell: default, EOL: 0
. 2012-02-16 12:11:03.933 Local directory: default, Remote directory: /home/xxx, Update: No, Cache: Yes
. 2012-02-16 12:11:03.933 Cache directory changes: Yes, Permanent: Yes
. 2012-02-16 12:11:03.933 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2012-02-16 12:11:03.933 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2012-02-16 12:11:25.215 Copying 1 files/directories to local directory "xxx_Desktop\"
. 2012-02-16 12:11:25.215 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2012-02-16 12:11:25.215 TM: M; ClAr: No; ExclM(No):
. 2012-02-16 12:11:25.215 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2012-02-16 12:11:25.215 Sent 108 bytes
. 2012-02-16 12:11:25.215 There are 0 bytes remaining in the send buffer
. 2012-02-16 12:11:25.215 Sent 1 bytes
> 2012-02-16 12:11:25.215 echo "WinSCP: this is begin-of-file" ; scp -r -p -d -f "syslog_info" ; echo "WinSCP: this is end-of-file:$?"
. 2012-02-16 11:56:49.497 Tunnel: No
. 2012-02-16 11:56:49.497 Transfer Protocol: SFTP (SCP)
. 2012-02-16 11:56:49.497 Ping type: N, Ping interval: 30 sec; Timeout: 15 sec
. 2012-02-16 11:56:49.497 Proxy: none
. 2012-02-16 11:56:49.497 SSH protocol version: 2; Compression: No
. 2012-02-16 11:56:49.497 Bypass authentication: No
. 2012-02-16 11:56:49.497 Try agent: No; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2012-02-16 11:56:49.497 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2012-02-16 11:56:49.497 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2012-02-16 11:56:49.497 SFTP Bugs: -,-
. 2012-02-16 11:56:49.497 Return code variable: Autodetect; Lookup user groups: Yes
. 2012-02-16 11:56:49.497 Shell: default
. 2012-02-16 11:56:49.497 EOL: 0, UTF: 2
. 2012-02-16 11:56:49.497 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2012-02-16 11:56:49.497 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2012-02-16 11:56:49.497 Local directory: default, Remote directory: /home/xxx, Update: No, Cache: Yes
. 2012-02-16 11:56:49.497 Cache directory changes: Yes, Permanent: Yes
. 2012-02-16 11:56:49.497 DST mode: 1
. 2012-02-16 11:57:06.810 Copying 1 files/directories to local directory "xxx_Desktop\"
. 2012-02-16 11:57:06.810 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2012-02-16 11:57:06.810 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2012-02-16 11:57:06.810 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2012-02-16 11:57:06.810 Sent 108 bytes
. 2012-02-16 11:57:06.810 There are 0 bytes remaining in the send buffer
. 2012-02-16 11:57:06.810 Looking for network events
. 2012-02-16 11:57:06.810 Timeout waiting for network events
. 2012-02-16 11:57:06.810 Sent 1 bytes
> 2012-02-16 11:57:06.810 echo "WinSCP: this is begin-of-file" ; scp -r -p -d -f "syslog_info" ; echo "WinSCP: this is end-of-file:$?"
. 2012-02-16 11:57:06.810 Waiting for another 1 bytes
. 2012-02-16 11:57:06.810 Looking for incoming data
. 2012-02-16 11:57:06.919 Detected network event
. 2012-02-16 11:57:06.919 Enumerating network events for socket 604
. 2012-02-16 11:57:06.919 Enumerated 1 network events making 1 cumulative events for socket 604
. 2012-02-16 11:57:06.919 Handling network read event on socket 604 with error 0
. 2012-02-16 11:57:06.919 Received 30 bytes (0)
. 2012-02-16 11:57:06.919 Read 1 bytes (29 pending)
. 2012-02-16 11:57:06.919 Read 29 bytes (0 pending)
< 2012-02-16 11:57:06.919 WinSCP: this is begin-of-file
. 2012-02-16 11:57:06.919 Sending NULL.
. 2012-02-16 11:57:06.919 Sent 1 bytes
. 2012-02-16 11:57:06.919 There are 0 bytes remaining in the send buffer
. 2012-02-16 11:57:06.919 Looking for network events
. 2012-02-16 11:57:06.919 Timeout waiting for network events
. 2012-02-16 11:57:06.919 Waiting for another 1 bytes
. 2012-02-16 11:57:06.919 Looking for incoming data
. 2012-02-16 11:57:06.935 Detected network event
. 2012-02-16 11:57:06.935 Enumerating network events for socket 604
. 2012-02-16 11:57:06.935 Enumerated 1 network events making 1 cumulative events for socket 604
. 2012-02-16 11:57:06.935 Handling network read event on socket 604 with error 0
. 2012-02-16 11:57:06.935 Received 27 bytes (0)
. 2012-02-16 11:57:06.935 Read 1 bytes (26 pending)
. 2012-02-16 11:57:06.935 Read 26 bytes (0 pending)
< 2012-02-16 11:57:06.935 T1329122163 0 1329382479 0
. 2012-02-16 11:57:06.935 Sending NULL.
. 2012-02-16 11:57:06.935 Sent 1 bytes
. 2012-02-16 11:57:06.935 There are 0 bytes remaining in the send buffer
. 2012-02-16 11:57:06.935 Looking for network events
. 2012-02-16 11:57:06.935 Timeout waiting for network events
. 2012-02-16 11:57:06.935 Waiting for another 1 bytes
. 2012-02-16 11:57:06.935 Looking for incoming data
< 2012-02-16 11:57:06.935 C0640 47654602 syslog_info
. 2012-02-16 11:57:32.451 Enumerating network events for socket 604
. 2012-02-16 11:57:32.451 Enumerated 33 network events making 33 cumulative events for socket 604
. 2012-02-16 11:57:32.451 Handling network read event on socket 604 with error 0
. 2012-02-16 11:57:32.451 Handling network close event on socket 604 with error 0
. 2012-02-16 11:57:32.451 Selecting events 0 for socket 604
. 2012-02-16 11:57:32.451 Server unexpectedly closed network connection
* 2012-02-16 11:57:32.451 (ESshFatal) Server unexpectedly closed network connection.
* 2012-02-16 11:57:32.451 Copying file 'syslog_info' fatally failed.
* 2012-02-16 11:57:32.451 Copying files from remote side failed.
Have you tried to follow my suggestion?
Boris Berdichevski
I tried to install version 4.1.9 -- all's Ok!
And next version have the bug.
Again, have you tried 5.0.6 beta with disabled Optimize connection buffer size?
infiniteegolfer
In version 5.5, which I just downloaded, disabling 'Optimize connection buffer size' does indeed solve the problem.
This is not in the global preferences, but rather in the settings for the connection. To disable it:
Edit the Session
Click the 'Advanced...' button
Select 'Connection'
Uncheck 'Optimize connection buffer size'
Save and enjoy downloading large files once again.
Edit the Session
Select 'Connection'
Thanks for your feedback. Any chance of getting a test account on your server?
