Topic "PLEASE tell how how to set default start folders!!"
allesok
I cannot find out how to set the default folders with which WinSCP starts but have to click through several each time I started it.
PLEASE LET ME KNOW HOW TO DO THAT!!!
Stop spamming
http://winscp.net/forum/viewtopic.php?t=10856
allesok
You may not like to read this, but this is a non-feature in WinSCP (that seems to be improved in the beta version?).
It must necessarily be possible to change such settings after creating a login instead of having to recreate the whole login only to have such settings saved!
A menu item in the opened session should enable a settings modification of this kind.
Here an improvement is certainly needed.
Petr
Moderator
Directories tab allows user to configure initial session directories and the way how directory content is read. You do NOT have to recreate login! Select existing stored session and click Edit. Then follow http://winscp.net/eng/docs/ui_login_directories and save.
