Topic "Scheduled download"
PaddyCJ
Hi All,
I'm quite new to this so please bear with me.
Ive hashed together a script that script that is meant to connect to a secure FTP site, Ive created a session and used that to open the connection via WINSCP.COM but the files do not download to the desired location.
Heres the command that Im using;
winscp.com /command "open ""P-CARDS""" "GET ""P:\TestP-CardsIn""" /log="P:\TestP-CardsLog\WinSCPLogs\winscp.log" "exit"
Im hoping to later on setup this up as a scheduled task as it will need to down load a new file daily.
Any help would be appreciated.
The first argument to get is remote path to download files from. Also if TestP-CardsIn is local folder, you need to terminate the path with backslash:
"GET /remote/folder/to/download/files/from/* P:\TestP-CardsIn\"
PaddyCJ
Thanks I'll give it a go.
PaddyCJ
Thanks a lot Prikryl that worked like a charm Very Happy
