Topic "How to set same permissions for files"
Dear Sir,
I have a unix server, in its root folder we have created a folder with name test.
If 1 user creates a file in that folder say test.txt it is being assigned rights as drwxrwxr-x
so even other user is able to delete the file in that folder.
but when i create a file from winscp in that folder only the owener of that file can modify or delete that file.
How to give the same permissions as of putty so that any user can have write permissions for the files.
You can set the default permissions in preferences:
thanks my issue has been resolved
