Topic "password with @"
rpolichetti
While using this template:
sftp://martin:mypassword@example.com
the password I'm trying to use has the @ symbol which is confusing the parser.
Can the password be quoted or the @ in the password be escaped or something else?
Richard
Please read documentation:
http://winscp.net/eng/docs/session_url
Alexyau
I read the link and understood that special character needed to be replaced by %XX where XX is hexadecimal ASCII code.
I tried to connect to the FTP server(Windows 2008) and the user name is abc-dms\ABCDE. I have tried abc%2Ddms%5CABCDE and abc-dms%5CABCDE but both didn't work.
Any other suggestion?
Alex
Actually there's no need to encode nether \ nor -.
So the problem has to be elsewhere.
Alexyau
First, I am running the script in command-line.
For example, running test.bat to run test.txt.
test.bat: winscp /console /script=c:\test.txt
test.txt:
option batch abort
open pcn-dms\DCN020A004:12345@site
cd /test_transfer_log
lcd C:\New_DMSInterface_Test\LOG
get -delete *.*
cd /test_transfer
lcd C:\New_DMSInterface_Test\PROCESSED
get -delete *.*
close
BTW, how I can get the full log file if I run the script in command-line mode.
Alex
Alexyau
As suggested, I found the /log option, added to the command line and reviewed the log.
The problem was the default protocol was using SFTP while my remote server was using FTP. So I have added "ftp://" in the open command and it worked.
Thanks very much for your assistance and WinSCP is indeed a great product.
Alex
