Topic "Error Message"
stoughton
I have the latest version of WinSCP, I am trying to log in and I get the following error message:
Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
I manually changed my shell to /bin/bash, and I get the same error message.
I am supposed to be getting a startup message allowing an EWR upgrade, but I don't get the message with the option to allow the upgrade. I just get the error message above.
If you are supposed to get a menu after startup, than you you most likely supposed to use SSH terminal (such as PuTTY), not file transfer client.
Otherwise, please post a full log file showing the problem.
