Topic "cannot focus re-login dialog when transfer dialog is focused"
zumla
I use public key authentication.
When a session is closed (or broken?) and WinSCP doesn't notice that since my machine going to sleep mode,
then I start downloading a file from remote host, transfer dialog is opened which is grabbing the focus,
so I cannot input into re-login dialog.
WinSCP 4.3.7, Windows 7
Can you please describe the scenario into more details? Step by step.
zumla
1. establish a WinSCP connection
2. make Windows to be sleep mode (maybe the connection is broken)
3. back to working on WinSCP
4. open for editing a remote file, then transfer dialog which grabbing the focus is opened
5. attempt to reconnect by type my password into login dialog.
6. however, the dialog isn't shown, is shown only in thumbnails on `Alt+Tab' task switching view
Sorry, I'm probably missing at what point the connection is lost. During the transfer? I'm still not able to reproduce the problem. Can you give me even more details?
zumla
umm...
I haven't been experienced the same situation.
thank you.
