Topic "exit closes batch in beta"
Someguy
I have a DOS batch file that contains the following:
@echo off
winscp.com /command "open test_session" "option batch abort" "option confirm off" "get test.dat" "close" "exit"
echo %errorlevel%
Using beta 5.0.6, the last echo is not done. It seems that the exit closes the batch. Using 4.3.7 I get the errorlevel.
Also, in beta, the new line in the stdout is only "0A" instead of "0A 0D".
Thanks.
Someguy
"0A 0D" should be "0D 0A"
I will take a look at this issue.
@echo off
echo %errorlevel%
I cannot reproduce the problem. For me the errorlevel is printed.
This issue has been added to tracker:
http://winscp.net/tracker/show_bug.cgi?id=812
Someguy
Mail sent.
Someguy
I think I have further tracked down the problem.
When running winscp.com in a DOS session and then immediately exit without any action, after I am not able to run any batch script in the same DOS session.
Example:
C:\TEMP\1>test_scp.cmd
I am here
C:\TEMP\1>winscp.com
winscp> exit
C:\TEMP\1>
test_scp.cmd contains:
@echo I am here
Tried this on Windows XP.
Thanks for your investigation.
This bug has been added to tracker:
http://winscp.net/tracker/show_bug.cgi?id=814
