Topic "passphrase prompts in batch"
Someguy
In console batch mode when you have a private key with password, even if using "option batch abort" "option confirm off", you get a prompt blocking the script instead of an abort.
Thanks.
The prompt should timeout after 10 seconds.
What vrsion of WinsCP are you using?
Someguy
You are right, I tried to replicate the problem and there is a timeout after 10 seconds.
I don't know how I got that problem in the first place.
This report can be ignored then, thanks.
zeiglerw2
Can you show an example of where to properly put "option batch abort"? Here is the command I am using:
C:\WinSCP.exe /console Stored_Session /command "cd Some/Directory" "put some*.file"
Where would I put option batch abort? ... as a command in quote?
C:\WinSCP.exe /console /command "option batch abort" "open Stored_Session" "cd Some/Directory" "put some*.file"
http://winscp.net/eng/docs/scripting#example
