Topic "window needs focus before menus etc work"
jrichemont
Hi. This is a small thing but a bit annoying. It applies to every version of winSCP I have tried including 5.0.5 (1782) that I am using now.
When another window has focus - such as an editor - move the mouse back to the winSCP window and click any menu. The whole window 'blinks' but ignores the mouse click. Click again and you get your menu.
If you work with an editor and use winSCP to edit files on a remote system it gets a bit annoying to have to 'double-click' each time you go back to winSCP from the editor.
Cheers;
Jeremy
jrichemont
This is reposted because I registered after posting the first time and I wanted to get emailed of any responses.
Cheers;
Jeremy
jrichemont wrote:
...copy of above...
I will take a look at this issue.
