Topic "Cannot access Directories"
Hello *,
i cant list any directory on my mediaplayer.
I think it is the same problem as here:
I try to access my Mediaplayer with WINSCP. There is a stupid-ftpd installed.
With Filezilla all is working very well, also with standard Windows FTP command.
I have already tested with active and passiv ftp, no success...
Can anybody help me ?
See my log file:
WinSCP Version 4.3.7 (Build 1679) (OS 6.1.7601 Service Pack 1)
Configuration: C:\Program Files (x86)\WinSCP\WinSCP.ini
Local account: Klaus_Desktop\Klaus Voigt
Login time: Mittwoch, 7. Mrz 2012 18:28:25
Session name: PlayonHD (Stored session)
Host name: (Port: 21)
User name: anonymous (Password: Yes, Key file: No)
Tunnel: No
Transfer Protocol: FTP
Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
Proxy: none
FTP: FTPS: None; Passive: No [Force IP: No]
Local directory: E:\Software & Treiber\Driver & Updates\Playon!HD Mini ACR-PV73200, Remote directory: /, Update: Yes, Cache: No
Cache directory changes: No, Permanent: Yes
DST mode: 1
Connecting to ...
Connected with Waiting for welcome message...
220 Welcome to Stupid-FTPd server.
USER anonymous
331 Guest login ok, send your e-mail address as password.
PASS ****
230 User anonymous logged in.
215 UNIX Type: L8 (Linux).
503 Command not understood.
Using FTP protocol.
Doing startup conversation with host.
257 "/" is current directory.
Changing directory to "/".
250 CWD command successful.
Getting current directory name.
Retrieving directory listing...
200 Type set to A.
PORT 192,168,1,3,245,19
200 PORT command successful.
150 OK
226 Transfer complete.
Directory listing successful
Startup conversation with host finished.
Changing directory to "usr".
CWD usr
257 "usr/" is current directory.
CWD /usr/usr/
550 /usr/usr/: No such directory.
(ECommand) Error listing directory 'usr'.
I have played around.
WINSCP has no problem with servers who respond to pwd with /folder, but when the server respond with folder/, i get the error.
Unfortunetly i have no possibilty to control this behavior.
Ok, when i sent cwd commands via terminal to my server i can navigate to my wanted folder.
I find it is clear, the problem is / before and / behind the folder.
Hopefully it will be fixed.
I have sent you the mail ....
Here are some duplicates of the report of this problem:
OK, so I installed this ftp server on my Android 4.2.1 tablet
and using the option "Restrict to Default Directory"!searchin/andreasliebigapps/Restrict$20to$20Default$20Directory|sort:relevance/andreasliebigapps/HnDwBgyZKgU/-wBGis83FrgJ
is what's causing the problem. That is kind of security setting on ftp server, honoured by Winscp, but not by other ftp clients, notably by standard built in Windows CLI client or Filezilla, they all seem to work and provide access to other directories, as already mentioned in this thread. That's kind of hypothesis by now, didn't have chance to try to untick that option yet, but I'll let you know.
Unfortunately, that does not help. There is some other problem with that ftp server in conjuction with WinSCP. Sad
