Topic "uploading problem with script"
Ben2012
I set up a scheduled job using script to upload a file to a FTPS server. Most of the time it works fine, but once a while the uploading process hangs. After I explicitly add certificate fingerprint as the parameter (/certificate="xx:xx:...."), the problem still exists. I am not sure if it is caused by client side or server side. The following is the WinSCP log. How do I debug this problem? Thanks for your help!
. 2012-03-11 10:12:44.441 --------------------------------------------------------------------------
. 2012-03-11 10:12:44.441 WinSCP Version 4.3.2 (Build 1201) (OS 5.2.3790 Service Pack 2)
. 2012-03-11 10:12:44.441 Login time: Tuesday, March 11, 2012 10:12:44 AM
. 2012-03-11 10:12:44.441 Session name: TestSession@11.22.33.44
. 2012-03-11 10:12:44.441 Host name: 11.22.33.44 (Port: 990)
. 2012-03-11 10:12:44.441 User name: TestUser (Password: Yes, Key file: No)
. 2012-03-11 10:12:44.441 Tunnel: No
. 2012-03-11 10:12:44.441 Transfer Protocol: FTP
. 2012-03-11 10:12:44.441 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2012-03-11 10:12:44.441 Proxy: none
. 2012-03-11 10:12:44.441 FTP: FTPS: Implicit SSL/TLS; Passive: Yes [Force IP: Yes]
. 2012-03-11 10:12:44.441 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2012-03-11 10:12:44.441 Cache directory changes: Yes, Permanent: Yes
. 2012-03-11 10:12:44.441 DST mode: 1
. 2012-03-11 10:12:44.628 Connecting to 11.22.33.44:990 ...
. 2012-03-11 10:12:44.691 Connected with 11.22.33.44:990, negotiating SSL connection...
. 2012-03-11 10:12:44.894 SSL connection established. Waiting for welcome message...
< 2012-03-11 10:12:45.128 220 Serv-U FTP Server v10.5 ready...
> 2012-03-11 10:12:45.128 USER TestUser
< 2012-03-11 10:12:45.206 331 User name okay, need password.
> 2012-03-11 10:12:45.206 PASS *********
< 2012-03-11 10:12:45.269 230 User logged in, proceed.
> 2012-03-11 10:12:45.269 SYST
< 2012-03-11 10:12:45.331 215 UNIX Type: L8
> 2012-03-11 10:12:45.331 FEAT
< 2012-03-11 10:12:45.394 211-Extensions supported
< 2012-03-11 10:12:45.394 UTF8
< 2012-03-11 10:12:45.394 OPTS MODE;MLST;UTF8
< 2012-03-11 10:12:45.394 CLNT
< 2012-03-11 10:12:45.394 CSID Name; Version;
< 2012-03-11 10:12:45.394 HOST domain
< 2012-03-11 10:12:45.394 SITE PSWD;SET;ZONE;CHMOD;MSG;EXEC;HELP
< 2012-03-11 10:12:45.394 AUTH TLS;SSL;TLS-C;TLS-P;
< 2012-03-11 10:12:45.394 PBSZ
< 2012-03-11 10:12:45.394 PROT
< 2012-03-11 10:12:45.394 CCC
< 2012-03-11 10:12:45.394 SSCN
< 2012-03-11 10:12:45.394 RMDA directoryname
< 2012-03-11 10:12:45.394 DSIZ
< 2012-03-11 10:12:45.394 AVBL
< 2012-03-11 10:12:45.394 EPRT
< 2012-03-11 10:12:45.394 EPSV
< 2012-03-11 10:12:45.394 MODE Z
< 2012-03-11 10:12:45.394 THMB BMP|JPEG|GIF|TIFF|PNG max_width max_height pathname
< 2012-03-11 10:12:45.394 REST STREAM
< 2012-03-11 10:12:45.394 SIZE
< 2012-03-11 10:12:45.394 MDTM
< 2012-03-11 10:12:45.394 MDTM YYYYMMDDHHMMSS[+-TZ];filename
< 2012-03-11 10:12:45.394 MFMT
< 2012-03-11 10:12:45.394 MFCT
< 2012-03-11 10:12:45.394 MFF Create;Modify;
< 2012-03-11 10:12:45.394 XCRC filename;start;end
< 2012-03-11 10:12:45.394 MLST Type*;Size*;Create;Modify*;Perm;Win32.ea;Win32.dt;Win32.dl
< 2012-03-11 10:12:45.394 211 End (for details use "HELP commmand" where command is the command of interest)
> 2012-03-11 10:12:45.394 CLNT FileZilla
< 2012-03-11 10:12:45.440 200 Noted.
> 2012-03-11 10:12:45.440 OPTS UTF8 ON
< 2012-03-11 10:12:45.503 200 OPTS UTF8 is set to ON.
> 2012-03-11 10:12:45.503 PBSZ 0
< 2012-03-11 10:12:45.565 200 PBSZ command OK. Protection buffer size set to 0.
> 2012-03-11 10:12:45.565 PROT P
< 2012-03-11 10:12:45.612 200 PROT command OK. Using private data connection.
. 2012-03-11 10:12:45.612 Connected
. 2012-03-11 10:12:45.612 --------------------------------------------------------------------------
. 2012-03-11 10:12:45.612 Using FTP protocol.
. 2012-03-11 10:12:45.612 Doing startup conversation with host.
> 2012-03-11 10:12:45.628 PWD
< 2012-03-11 10:12:45.675 257 "/" is current directory.
. 2012-03-11 10:12:45.675 Getting current directory name.
. 2012-03-11 10:12:45.675 Startup conversation with host finished.
< 2012-03-11 10:12:45.675 Script: Active session: [1] TestUser@11.22.33.44
> 2012-03-11 10:12:45.675 Script: option confirm off
< 2012-03-11 10:12:45.675 Script: confirm off
> 2012-03-11 10:12:45.675 Script: pwd
< 2012-03-11 10:12:45.675 Script: /
> 2012-03-11 10:12:45.675 Script: ascii
< 2012-03-11 10:12:45.675 Script: transfer ascii
> 2012-03-11 10:12:45.690 Script: put testfile.txt
. 2012-03-11 10:12:45.690 Copying 1 files/directories to remote directory "/"
. 2012-03-11 10:12:45.690 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2012-03-11 10:12:45.690 TM: A; ClAr: No; CPS: 0; ExclM(No):
. 2012-03-11 10:12:45.690 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2012-03-11 10:12:45.690 File: "testfile.txt"
. 2012-03-11 10:12:45.690 Copying "testfile.txt" to remote directory started.
. 2012-03-11 10:12:45.690 Ascii transfer mode selected.
. 2012-03-11 10:12:45.690 Starting upload of testfile.txt
> 2012-03-11 10:12:45.690 TYPE A
< 2012-03-11 10:12:45.753 200 Type set to A.
> 2012-03-11 10:12:45.753 PASV
< 2012-03-11 10:12:45.815 227 Entering Passive Mode (10,11,10,44,7,208)
. 2012-03-11 10:12:45.815 Using host address 11.22.33.44 instead of the one suggested by the server: 10.11.10.44
> 2012-03-11 10:12:45.815 LIST
< 2012-03-11 10:12:45.878 150 Opening ASCII mode data connection for /bin/ls.
< 2012-03-11 10:17:45.851 451 Operation aborted due to ABOR command.
. 2012-03-11 10:17:45.851 Copying files to remote side failed.
* 2012-03-11 10:17:45.851 (ExtException) Using host address 11.22.33.44 instead of the one suggested by the server: 10.11.10.44
* 2012-03-11 10:17:45.851 Copying files to remote side failed.
* 2012-03-11 10:17:45.851 Operation aborted due to ABOR command.
. 2012-03-11 10:17:45.851 Asking user:
. 2012-03-11 10:17:45.851 Error transferring file 'testfile.txt'. ("Using host address 11.22.33.44 instead of the one suggested by the server: 10.11.10.44","Copying files to remote side failed.","Operation aborted due to ABOR command.")
I also got the log from the server side - FTP SSL data socket timed out during SSL shutdown sequence. The FTPS client did not complete SSL shutdown, please contact client manufacturer.
Please try to upgrade to the latest vesion first.
