Topic "Cannot uncheck passive mode"
albgen
I'm using winscp 5.0.6 (build 2074). As subject of this discussione, i cant set winscp to active mode. The checkbox "Passive mode" is disabled.
http://desmond.imageshack.us/Himg52/scaled.php?server=52&filename=150320121129.png&res=medium
Why i cant?
Thank you
Passive mode is a feature of FTP only I'm afraid.
Quote:
Passive mode is special mode of FTP protocol. It is enabled by default. Disable it only when needed. The option is supported only with FTP protocol.
http://winscp.net/eng/docs/ui_login_connection
Exactly.
So if you want to use FTP, make sure you select FTP protocol before turning off passive mode.
albgen
Thank you
