Topic "Connecting to Filezilla server - WinSCP 425s"
robatwork
I have a filezilla server across the internet. Due to a router issue I had to set it to forward port 2121 to port 21, and also forward passive ports 50000 to 50100, and in filezilla server I have manually set those passive ports.
Filezilla client can connect fine and list the directory:
000036) 22/03/2012 11:53:06 - (not logged in) (78.xxx.xxx.87)> Connected, sending welcome message...
(000036) 22/03/2012 11:53:06 - (not logged in) (78.xxx.xxx.87)> 220-FileZilla Server version 0.9.32 beta
(000036) 22/03/2012 11:53:06 - (not logged in) (78.xxx.xxx.87)> 220-written by Tim Kosse (Tim.Kosse@gmx.de)
(000036) 22/03/2012 11:53:06 - (not logged in) (78.xxx.xxx.87)> 220 Please visitxxxx
(000036) 22/03/2012 11:53:06 - (not logged in) (78.xxx.xxx.87)> USER test_login
(000036) 22/03/2012 11:53:06 - (not logged in) (78.xxx.xxx.87)> 331 Password required for test_login
(000036) 22/03/2012 11:53:06 - (not logged in) (78.xxx.xxx.87)> PASS ********************************
(000036) 22/03/2012 11:53:06 - test_login (78.xxx.xxx.87)> 230 Logged on
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> SYST
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> 215 UNIX emulated by FileZilla
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> FEAT
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> 211-Features:
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> MDTM
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> REST STREAM
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> SIZE
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> MLST type*;size*;modify*;
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> MLSD
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> UTF8
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> CLNT
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> MFMT
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> 211 End
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> PWD
(000036) 22/03/2012 11:53:07 - test_login (78.xxx.xxx.87)> 257 "/" is current directory.
(000036) 22/03/2012 11:53:08 - test_login (78.xxx.xxx.87)> TYPE I
(000036) 22/03/2012 11:53:08 - test_login (78.xxx.xxx.87)> 200 Type set to I
(000036) 22/03/2012 11:53:08 - test_login (78.xxx.xxx.87)> PASV
(000036) 22/03/2012 11:53:08 - test_login (78.xxx.xxx.87)> 227 Entering Passive Mode (192,168,1,66,195,95)
(000036) 22/03/2012 11:53:09 - test_login (78.xxx.xxx.87)> MLSD
(000036) 22/03/2012 11:53:09 - test_login (78.xxx.xxx.87)> 150 Connection accepted
(000036) 22/03/2012 11:53:09 - test_login (78.xxx.xxx.87)> 226 Transfer OK
When I connect from WinSCP (both my old version and the new Beta 506) it connects fine but it won't list the folder - I get:
(000037) 22/03/2012 11:53:41 - (not logged in) (78.xxx.xxx.87)> Connected, sending welcome message...
(000037) 22/03/2012 11:53:41 - (not logged in) (78.xxx.xxx.87)> 220-FileZilla Server version 0.9.32 beta
(000037) 22/03/2012 11:53:41 - (not logged in) (78.xxx.xxx.87)> 220-written by Tim Kosse (Tim.Kosse@gmx.de)
(000037) 22/03/2012 11:53:41 - (not logged in) (78.xxx.xxx.87)> 220 Please visit xxx
(000037) 22/03/2012 11:53:41 - (not logged in) (78.xxx.xxx.87)> USER test_login
(000037) 22/03/2012 11:53:41 - (not logged in) (78.xxx.xxx.87)> 331 Password required for test_login
(000037) 22/03/2012 11:53:42 - (not logged in) (78.xxx.xxx.87)> PASS ********************************
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> 230 Logged on
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> SYST
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> 215 UNIX emulated by FileZilla
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> FEAT
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> 211-Features:
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> MDTM
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> REST STREAM
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> SIZE
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> MLST type*;size*;modify*;
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> MLSD
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> UTF8
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> CLNT
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> MFMT
(000037) 22/03/2012 11:53:42 - test_login (78.xxx.xxx.87)> 211 End
(000037) 22/03/2012 11:53:43 - test_login (78.xxx.xxx.87)> PWD
(000037) 22/03/2012 11:53:43 - test_login (78.xxx.xxx.87)> 257 "/" is current directory.
(000037) 22/03/2012 11:53:43 - test_login (78.xxx.xxx.87)> CWD /
(000037) 22/03/2012 11:53:43 - test_login (78.xxx.xxx.87)> 250 CWD successful. "/" is current directory.
(000037) 22/03/2012 11:53:44 - test_login (78.xxx.xxx.87)> PWD
(000037) 22/03/2012 11:53:44 - test_login (78.xxx.xxx.87)> 257 "/" is current directory.
(000037) 22/03/2012 11:53:44 - test_login (78.xxx.xxx.87)> TYPE A
(000037) 22/03/2012 11:53:44 - test_login (78.xxx.xxx.87)> 200 Type set to A
(000037) 22/03/2012 11:53:45 - test_login (78.xxx.xxx.87)> PORT 192,168,0,216,247,156
(000037) 22/03/2012 11:53:45 - test_login (78.xxx.xxx.87)> 200 Port command successful
(000037) 22/03/2012 11:53:45 - test_login (78.xxx.xxx.87)> LIST
(000037) 22/03/2012 11:53:45 - test_login (78.xxx.xxx.87)> 150 Opening data channel for directory list.
(000037) 22/03/2012 11:53:56 - test_login (78.xxx.xxx.87)> 425 Can't open data connection.
(000037) 22/03/2012 11:54:08 - test_login (78.xxx.xxx.87)> disconnected.
If I force winSCP to passive I get
WINSCP
Can't open data connection:
(000038) 22/03/2012 11:54:59 - (not logged in) (78.xxx.xxx.87)> Connected, sending welcome message...
(000038) 22/03/2012 11:54:59 - (not logged in) (78.xxx.xxx.87)> 220-FileZilla Server version 0.9.32 beta
(000038) 22/03/2012 11:54:59 - (not logged in) (78.xxx.xxx.87)> 220-written by Tim Kosse (Tim.Kosse@gmx.de)
(000038) 22/03/2012 11:54:59 - (not logged in) (78.xxx.xxx.87)> 220 Please visit xxx
(000038) 22/03/2012 11:54:59 - (not logged in) (78.xxx.xxx.87)> USER test_login
(000038) 22/03/2012 11:54:59 - (not logged in) (78.xxx.xxx.87)> 331 Password required for test_login
(000038) 22/03/2012 11:54:59 - (not logged in) (78.xxx.xxx.87)> PASS ********************************
(000038) 22/03/2012 11:54:59 - test_login (78.xxx.xxx.87)> 230 Logged on
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> SYST
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> 215 UNIX emulated by FileZilla
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> FEAT
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> 211-Features:
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> MDTM
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> REST STREAM
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> SIZE
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> MLST type*;size*;modify*;
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> MLSD
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> UTF8
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> CLNT
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> MFMT
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> 211 End
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> PWD
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> 257 "/" is current directory.
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> CWD /
(000038) 22/03/2012 11:55:00 - test_login (78.xxx.xxx.87)> 250 CWD successful. "/" is current directory.
(000038) 22/03/2012 11:55:01 - test_login (78.xxx.xxx.87)> TYPE A
(000038) 22/03/2012 11:55:01 - test_login (78.xxx.xxx.87)> 200 Type set to A
(000038) 22/03/2012 11:55:01 - test_login (78.xxx.xxx.87)> PASV
(000038) 22/03/2012 11:55:01 - test_login (78.xxx.xxx.87)> 227 Entering Passive Mode (192,168,1,66,195,96)
(000038) 22/03/2012 11:55:01 - test_login (78.xxx.xxx.87)> LIST
(000038) 22/03/2012 11:55:11 - test_login (78.xxx.xxx.87)> 425 Can't open data connection.
Any ideas why filezilla works but WinSCP doesn't?
Some further info is that CoreFTP client connects fine as well on port 2121
thanks for any help
Rob
Can you try it with the latest beta version and post (or email) a complete log file both from WinSCP and Filezilla?
robatwork
Hi Martin,
I checked all the forums here and saw that the latest beta had the option to tick "Force IP address" and that did the trick
thanks
emboman
i was having problem with the error 425: can't open data connection. I fixed the problem by creating firewall rule (i am using win7) and added rule for the passive ports (tcp, because FTP data is tcp oriented).
hope this helps
