Topic "Synchronize -filemask in .NET Assembly?"
3K
Hi, what is the equivalent scripting command of filemask in .NET Assembly as shown below?
Script:
synchronize -filemask="*.doc*<2012-02-01; *.ppt*<2012-02-01" local "C:\TEST\docs" "/docs"
In .NET assembly, what will be the filemask command?
synchronizationResult =
session.SynchronizeDirectories(
SynchronizationMode.Local, @"C:\TEST\docs", "/docs", false);
Thank you.
That would be:
    SynchronizationMode.Local, @"C:\TEST\docs", "/docs", false,
    options: new TransferOptions { FileMask = "*.doc*<2012-02-01; *.ppt*<2012-02-01" });
Read more here:
http://winscp.net/eng/docs/library_session_synchronizedirectories
http://winscp.net/eng/docs/library_transferoptions
3K
Thank you. Very Happy
John Thomas
Does the same Filemask syntax apply to session.PutfFiles also?
I need to transfer all the files in a directory without including any sub directories and delete source files on successful transfer.
Will the following code work?
TransferOptions transferOptions = new TransferOptions();
transferOptions.TransferMode = TransferMode.Binary;
transferOptions.FileMask = "*.*| */";
session.PutFiles(source\*, target, true, transferOptions);
Your code looks good. Any problems?
