Topic "Feature request: copy/move files between tabs."
webian
WinSCP 5 has tabs. I like this new feature!
Sadly I can't copy/move files between tabs, I have to open 2 WinSCP instances.
Is it possible to introduce this feature?
Thanks!
You do not have to:
http://winscp.net/eng/docs/task_move_duplicate
Sure.
http://winscp.net/tracker/show_bug.cgi?id=825
webian
You do not have to:
Sure.
Sorry, I didn't get your tip. What I can do is move/copy files/folders in a new path in the same tab or locally.
AFAIK I can't move/copy files/folder to another tab.
What I usually do with WinSCP 4 is to use two instances and drag&drop files/folder from one instance (dev server) to the other (prod server) via local copy.
Btw, thank you for the add!
Go to File > Duplicate. You will get a window, where you can select another opened session to duplicate the files to.
