Topic "Can command line disable GUI during /upload?"
kentdorsey
A client is attempting to automate an scp transfer using winscp3. When the following command line is issued:
winscp3 mysession@myhost /upload testfile.txt
GUI windows pop-up to confirm the copy, etc. Is there a way to make the transfer 100% automatic, with no user intervention required?
Kent Dorsey
WinSCP lacks scripting support. It will be added eventualy. Till then it think that using some command line SCP/SFTP client (like PSCP of PSFTP) is better choice.
/upload parameter was added for Explorer's "Send to" menu support. It was not intended for automation.
