Error Listing Directory '/" Could not retrieve directorylist
Mujahed Hussain
Appriciate if any body can help on this issue
. 2012-03-27 15:58:35.468 -----------------------------------------------------------------------------
. 2012-03-27 15:58:35.468 WinSCP Version 5.0.6 (Build 2074) (OS 5.1.2600 Service Pack 3)
. 2012-03-27 15:58:35.468 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2012-03-27 15:58:35.468 Local account: RODENIE\Administrator
. 2012-03-27 15:58:35.468 Login time: Tuesday, March 27, 2012 3:58:35 PM
. 2012-03-27 15:58:35.468 Session name: SESAMiFTPSQA@203.117.223.68 (Stored session)
. 2012-03-27 15:58:35.468 Host name: 203.117.223.68 (Port: 21)
. 2012-03-27 15:58:35.468 User name: SESAMiFTPSQA (Password: Yes, Key file: No)
. 2012-03-27 15:58:35.468 Tunnel: No
. 2012-03-27 15:58:35.468 Transfer Protocol: FTP
. 2012-03-27 15:58:35.468 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2012-03-27 15:58:35.468 Proxy: none
. 2012-03-27 15:58:35.468 FTP: FTPS: Explicit TLS; Passive: No [Force IP: No]
. 2012-03-27 15:58:35.468 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2012-03-27 15:58:35.468 Cache directory changes: Yes, Permanent: Yes
. 2012-03-27 15:58:35.468 DST mode: 1
. 2012-03-27 15:58:35.562 Connecting to 203.117.223.68 ...
. 2012-03-27 15:58:35.562 m_pSslLayer changed state from 0 to 1
. 2012-03-27 15:58:35.562 m_pSslLayer changed state from 1 to 2
. 2012-03-27 15:58:35.656 m_pSslLayer changed state from 2 to 4
. 2012-03-27 15:58:35.703 Connected with 203.117.223.68, negotiating SSL connection...
< 2012-03-27 15:58:35.765 220 Microsoft FTP Service
> 2012-03-27 15:58:35.765 AUTH TLS
< 2012-03-27 15:58:35.859 234 AUTH command ok. Expecting TLS Negotiation.
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 read server hello A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 read server certificate A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 read server done A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 write client key exchange A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 write change cipher spec A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 write finished A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 flush data
. 2012-03-27 15:58:36.375 SSL_connect: SSLv3 read finished A
. 2012-03-27 15:58:36.375 Using TLSv1, cipher TLSv1/SSLv3: AES128-SHA, 2048 bit RSA
. 2012-03-27 15:58:36.390 SSL connection established. Waiting for welcome message...
> 2012-03-27 15:58:36.390 USER SESAMiFTPSQA
< 2012-03-27 15:58:36.500 331 Password required for SESAMiFTPSQA.
> 2012-03-27 15:58:36.500 PASS ********
< 2012-03-27 15:58:36.640 230 User logged in.
> 2012-03-27 15:58:36.640 SYST
< 2012-03-27 15:58:36.765 215 Windows_NT
> 2012-03-27 15:58:36.765 FEAT
< 2012-03-27 15:58:36.875 211-Extended features supported:
< 2012-03-27 15:58:36.890 LANG EN*
< 2012-03-27 15:58:36.890 UTF8
< 2012-03-27 15:58:36.890 AUTH TLS;TLS-C;SSL;TLS-P;
< 2012-03-27 15:58:36.890 PBSZ
< 2012-03-27 15:58:36.890 PROT C;P;
< 2012-03-27 15:58:36.890 CCC
< 2012-03-27 15:58:36.890 HOST
< 2012-03-27 15:58:36.890 SIZE
< 2012-03-27 15:58:36.890 MDTM
< 2012-03-27 15:58:36.890 REST STREAM
< 2012-03-27 15:58:36.890 211 END
> 2012-03-27 15:58:36.890 OPTS UTF8 ON
< 2012-03-27 15:58:37.015 200 OPTS UTF8 command successful - UTF8 encoding now ON.
> 2012-03-27 15:58:37.015 PBSZ 0
< 2012-03-27 15:58:37.140 200 PBSZ command successful.
> 2012-03-27 15:58:37.140 PROT P
< 2012-03-27 15:58:37.265 200 PROT command successful.
. 2012-03-27 15:58:37.328 Connected
. 2012-03-27 15:58:37.328 Got reply 1 to the command 1
. 2012-03-27 15:58:37.328 --------------------------------------------------------------------------
. 2012-03-27 15:58:37.328 Using FTP protocol.
. 2012-03-27 15:58:37.328 Doing startup conversation with host.
> 2012-03-27 15:58:37.390 PWD
< 2012-03-27 15:58:37.515 257 "/" is current directory.
. 2012-03-27 15:58:37.515 Got reply 1 to the command 16
. 2012-03-27 15:58:37.578 Getting current directory name.
. 2012-03-27 15:58:37.765 Retrieving directory listing...
> 2012-03-27 15:58:37.765 TYPE A
< 2012-03-27 15:58:37.796 200 Type set to A.
> 2012-03-27 15:58:37.796 PORT 192,168,43,197,4,63
< 2012-03-27 15:58:37.937 501 Server cannot accept argument.
. 2012-03-27 15:58:37.953 Could not retrieve directory listing
. 2012-03-27 15:58:37.953 Got reply 4 to the command 2
. 2012-03-27 15:58:38.015 Retrieving directory listing...
> 2012-03-27 15:58:38.015 TYPE A
< 2012-03-27 15:58:38.156 200 Type set to A.
> 2012-03-27 15:58:38.156 PORT 192,168,43,197,4,64
< 2012-03-27 15:58:38.265 501 Server cannot accept argument.
. 2012-03-27 15:58:38.265 Could not retrieve directory listing
. 2012-03-27 15:58:38.265 Got reply 4 to the command 2
* 2012-03-27 15:58:38.390 (ECommand) Error listing directory '/'.
* 2012-03-27 15:58:38.390 Could not retrieve directory listing
* 2012-03-27 15:58:38.390 Server cannot accept argument.
. 2012-03-27 15:58:41.625 Startup conversation with host finished.
. 2012-03-27 15:58:42.468 Session upkeep
. 2012-03-27 15:58:42.968 Session upkeep
. 2012-03-27 15:58:43.468 Session upkeep
. 2012-03-27 15:58:43.640 Cached directory change via ".." to "/".
. 2012-03-27 15:58:43.640 Getting current directory name.
. 2012-03-27 15:58:43.640 Directory content loaded from cache.
. 2012-03-27 15:58:43.968 Session upkeep
. 2012-03-27 15:58:44.468 Session upkeep
. 2012-03-27 15:58:44.968 Session upkeep
. 2012-03-27 15:58:45.468 Session upkeep
. 2012-03-27 15:58:45.546 Cached directory change via ".." to "/".
. 2012-03-27 15:58:45.546 Getting current directory name.
. 2012-03-27 15:58:45.562 Directory content loaded from cache.
. 2012-03-27 15:58:45.906 Cached directory change via ".." to "/".
. 2012-03-27 15:58:45.906 Getting current directory name.
. 2012-03-27 15:58:45.906 Directory content loaded from cache.
. 2012-03-27 15:58:45.968 Session upkeep
. 2012-03-27 15:58:46.468 Session upkeep
. 2012-03-27 15:58:46.968 Session upkeep
. 2012-03-27 15:58:47.468 Session upkeep
. 2012-03-27 15:58:47.968 Session upkeep
. 2012-03-27 15:58:48.468 Session upkeep
. 2012-03-27 15:58:48.968 Session upkeep
. 2012-03-27 15:58:49.468 Session upkeep
. 2012-03-27 15:58:49.734 Got reply 1004 to the command 2
. 2012-03-27 15:58:49.734 Disconnected from server
