Topic "Could not able to retrive directory listing '/""
Mujahed Hussain
Appriciate if any body can help on this issue
. 2012-03-27 15:58:35.468 -----------------------------------------------------------------------------
. 2012-03-27 15:58:35.468 WinSCP Version 5.0.6 (Build 2074) (OS 5.1.2600 Service Pack 3)
. 2012-03-27 15:58:35.468 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2012-03-27 15:58:35.468 Local account: RODENIE\Administrator
. 2012-03-27 15:58:35.468 Login time: Tuesday, March 27, 2012 3:58:35 PM
. 2012-03-27 15:58:35.468 Session name: SESAMiFTPSQA@203.117.223.68 (Stored session)
. 2012-03-27 15:58:35.468 Host name: 203.117.223.68 (Port: 21)
. 2012-03-27 15:58:35.468 User name: SESAMiFTPSQA (Password: Yes, Key file: No)
. 2012-03-27 15:58:35.468 Tunnel: No
. 2012-03-27 15:58:35.468 Transfer Protocol: FTP
. 2012-03-27 15:58:35.468 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2012-03-27 15:58:35.468 Proxy: none
. 2012-03-27 15:58:35.468 FTP: FTPS: Explicit TLS; Passive: No [Force IP: No]
. 2012-03-27 15:58:35.468 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2012-03-27 15:58:35.468 Cache directory changes: Yes, Permanent: Yes
. 2012-03-27 15:58:35.468 DST mode: 1
. 2012-03-27 15:58:35.562 Connecting to 203.117.223.68 ...
. 2012-03-27 15:58:35.562 m_pSslLayer changed state from 0 to 1
. 2012-03-27 15:58:35.562 m_pSslLayer changed state from 1 to 2
. 2012-03-27 15:58:35.656 m_pSslLayer changed state from 2 to 4
. 2012-03-27 15:58:35.703 Connected with 203.117.223.68, negotiating SSL connection...
< 2012-03-27 15:58:35.765 220 Microsoft FTP Service
> 2012-03-27 15:58:35.765 AUTH TLS
< 2012-03-27 15:58:35.859 234 AUTH command ok. Expecting TLS Negotiation.
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 read server hello A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 read server certificate A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 read server done A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 write client key exchange A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 write change cipher spec A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 write finished A
. 2012-03-27 15:58:36.171 SSL_connect: SSLv3 flush data
. 2012-03-27 15:58:36.375 SSL_connect: SSLv3 read finished A
. 2012-03-27 15:58:36.375 Using TLSv1, cipher TLSv1/SSLv3: AES128-SHA, 2048 bit RSA
. 2012-03-27 15:58:36.390 SSL connection established. Waiting for welcome message...
> 2012-03-27 15:58:36.390 USER SESAMiFTPSQA
< 2012-03-27 15:58:36.500 331 Password required for SESAMiFTPSQA.
> 2012-03-27 15:58:36.500 PASS ********
< 2012-03-27 15:58:36.640 230 User logged in.
> 2012-03-27 15:58:36.640 SYST
< 2012-03-27 15:58:36.765 215 Windows_NT
> 2012-03-27 15:58:36.765 FEAT
< 2012-03-27 15:58:36.875 211-Extended features supported:
< 2012-03-27 15:58:36.890 LANG EN*
< 2012-03-27 15:58:36.890 UTF8
< 2012-03-27 15:58:36.890 AUTH TLS;TLS-C;SSL;TLS-P;
< 2012-03-27 15:58:36.890 PBSZ
< 2012-03-27 15:58:36.890 PROT C;P;
< 2012-03-27 15:58:36.890 CCC
< 2012-03-27 15:58:36.890 HOST
< 2012-03-27 15:58:36.890 SIZE
< 2012-03-27 15:58:36.890 MDTM
< 2012-03-27 15:58:36.890 REST STREAM
< 2012-03-27 15:58:36.890 211 END
> 2012-03-27 15:58:36.890 OPTS UTF8 ON
< 2012-03-27 15:58:37.015 200 OPTS UTF8 command successful - UTF8 encoding now ON.
> 2012-03-27 15:58:37.015 PBSZ 0
< 2012-03-27 15:58:37.140 200 PBSZ command successful.
> 2012-03-27 15:58:37.140 PROT P
< 2012-03-27 15:58:37.265 200 PROT command successful.
. 2012-03-27 15:58:37.328 Connected
. 2012-03-27 15:58:37.328 Got reply 1 to the command 1
. 2012-03-27 15:58:37.328 --------------------------------------------------------------------------
. 2012-03-27 15:58:37.328 Using FTP protocol.
. 2012-03-27 15:58:37.328 Doing startup conversation with host.
> 2012-03-27 15:58:37.390 PWD
< 2012-03-27 15:58:37.515 257 "/" is current directory.
. 2012-03-27 15:58:37.515 Got reply 1 to the command 16
. 2012-03-27 15:58:37.578 Getting current directory name.
. 2012-03-27 15:58:37.765 Retrieving directory listing...
> 2012-03-27 15:58:37.765 TYPE A
< 2012-03-27 15:58:37.796 200 Type set to A.
> 2012-03-27 15:58:37.796 PORT 192,168,43,197,4,63
< 2012-03-27 15:58:37.937 501 Server cannot accept argument.
. 2012-03-27 15:58:37.953 Could not retrieve directory listing
. 2012-03-27 15:58:37.953 Got reply 4 to the command 2
. 2012-03-27 15:58:38.015 Retrieving directory listing...
> 2012-03-27 15:58:38.015 TYPE A
< 2012-03-27 15:58:38.156 200 Type set to A.
> 2012-03-27 15:58:38.156 PORT 192,168,43,197,4,64
< 2012-03-27 15:58:38.265 501 Server cannot accept argument.
. 2012-03-27 15:58:38.265 Could not retrieve directory listing
. 2012-03-27 15:58:38.265 Got reply 4 to the command 2
* 2012-03-27 15:58:38.390 (ECommand) Error listing directory '/'.
* 2012-03-27 15:58:38.390 Could not retrieve directory listing
* 2012-03-27 15:58:38.390 Server cannot accept argument.
. 2012-03-27 15:58:41.625 Startup conversation with host finished.
. 2012-03-27 15:58:42.468 Session upkeep
. 2012-03-27 15:58:42.968 Session upkeep
. 2012-03-27 15:58:43.468 Session upkeep
. 2012-03-27 15:58:43.640 Cached directory change via ".." to "/".
. 2012-03-27 15:58:43.640 Getting current directory name.
. 2012-03-27 15:58:43.640 Directory content loaded from cache.
. 2012-03-27 15:58:43.968 Session upkeep
. 2012-03-27 15:58:44.468 Session upkeep
. 2012-03-27 15:58:44.968 Session upkeep
. 2012-03-27 15:58:45.468 Session upkeep
. 2012-03-27 15:58:45.546 Cached directory change via ".." to "/".
. 2012-03-27 15:58:45.546 Getting current directory name.
. 2012-03-27 15:58:45.562 Directory content loaded from cache.
. 2012-03-27 15:58:45.906 Cached directory change via ".." to "/".
. 2012-03-27 15:58:45.906 Getting current directory name.
. 2012-03-27 15:58:45.906 Directory content loaded from cache.
. 2012-03-27 15:58:45.968 Session upkeep
. 2012-03-27 15:58:46.468 Session upkeep
. 2012-03-27 15:58:46.968 Session upkeep
. 2012-03-27 15:58:47.468 Session upkeep
. 2012-03-27 15:58:47.968 Session upkeep
. 2012-03-27 15:58:48.468 Session upkeep
. 2012-03-27 15:58:48.968 Session upkeep
. 2012-03-27 15:58:49.468 Session upkeep
. 2012-03-27 15:58:49.734 Got reply 1004 to the command 2
. 2012-03-27 15:58:49.734 Disconnected from server
Description: (none)
Are you able to connect with any other FTPS client? Like Filezilla? If you are, please post its logs file too.
Mujahed Hussain
Hi Martin,
I tried the Filezilla and its working fine. Below is the log. Appriciate your help.
2012-03-29 16:54:02 1332 3 Status: Connecting to 203.117.223.68:21...
2012-03-29 16:54:02 1332 3 Status: Connection established, waiting for welcome message...
2012-03-29 16:54:02 1332 3 Trace: CFtpControlSocket::OnReceive()
2012-03-29 16:54:02 1332 3 Response: 220 Microsoft FTP Service
2012-03-29 16:54:02 1332 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-29 16:54:02 1332 3 Command: AUTH TLS
2012-03-29 16:54:02 1332 3 Response: 234 AUTH command ok. Expecting TLS Negotiation.
2012-03-29 16:54:02 1332 3 Status: Initializing TLS...
2012-03-29 16:54:02 1332 3 Trace: CTlsSocket::Handshake()
2012-03-29 16:54:02 1332 3 Trace: CTlsSocket::ContinueHandshake()
2012-03-29 16:54:02 1332 3 Trace: CTlsSocket::OnSend()
2012-03-29 16:54:02 1332 3 Trace: CTlsSocket::OnRead()
2012-03-29 16:54:03 1332 3 Trace: CTlsSocket::OnRead()
2012-03-29 16:54:03 1332 3 Trace: CTlsSocket::ContinueHandshake()
2012-03-29 16:54:03 1332 3 Trace: TLS Handshake successful
2012-03-29 16:54:03 1332 3 Trace: Cipher: AES-128-CBC, MAC: SHA1
2012-03-29 16:54:03 1332 3 Status: Verifying certificate...
2012-03-29 16:54:03 1332 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-29 16:54:03 1332 3 Command: USER SESAMiFTPSQA
2012-03-29 16:54:03 1332 3 Status: TLS/SSL connection established.
2012-03-29 16:54:03 1332 3 Trace: CFtpControlSocket::OnReceive()
2012-03-29 16:54:03 1332 3 Response: 331 Password required for SESAMiFTPSQA.
2012-03-29 16:54:03 1332 3 Command: PASS ********
2012-03-29 16:54:03 1332 3 Response: 230-Directory has 32,035,041,280 bytes of disk space available.
2012-03-29 16:54:03 1332 3 Response: 230 User logged in.
2012-03-29 16:54:03 1332 3 Command: SYST
2012-03-29 16:54:03 1332 3 Response: 215 Windows_NT
2012-03-29 16:54:03 1332 3 Command: FEAT
2012-03-29 16:54:03 1332 3 Response: 211-Extended features supported:
2012-03-29 16:54:03 1332 3 Response: LANG EN*
2012-03-29 16:54:03 1332 3 Response: UTF8
2012-03-29 16:54:03 1332 3 Response: AUTH TLS;TLS-C;SSL;TLS-P;
2012-03-29 16:54:03 1332 3 Response: PBSZ
2012-03-29 16:54:03 1332 3 Response: PROT C;P;
2012-03-29 16:54:03 1332 3 Response: CCC
2012-03-29 16:54:03 1332 3 Response: HOST
2012-03-29 16:54:03 1332 3 Response: SIZE
2012-03-29 16:54:03 1332 3 Response: MDTM
2012-03-29 16:54:03 1332 3 Response: REST STREAM
2012-03-29 16:54:03 1332 3 Response: 211 END
2012-03-29 16:54:03 1332 3 Command: OPTS UTF8 ON
2012-03-29 16:54:03 1332 3 Response: 200 OPTS UTF8 command successful - UTF8 encoding now ON.
2012-03-29 16:54:03 1332 3 Command: PBSZ 0
2012-03-29 16:54:04 1332 3 Trace: CTlsSocket::OnRead()
2012-03-29 16:54:04 1332 3 Trace: CFtpControlSocket::OnReceive()
2012-03-29 16:54:04 1332 3 Response: 200 PBSZ command successful.
2012-03-29 16:54:04 1332 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-29 16:54:04 1332 3 Command: PROT P
2012-03-29 16:54:04 1332 3 Response: 200 PROT command successful.
2012-03-29 16:54:04 1332 3 Status: Connected
2012-03-29 16:54:04 1332 3 Trace: CFtpControlSocket::ResetOperation(0)
2012-03-29 16:54:04 1332 3 Trace: CControlSocket::ResetOperation(0)
2012-03-29 16:54:04 1332 3 Trace: CFileZillaEnginePrivate::ResetOperation(0)
2012-03-29 16:54:04 1332 3 Status: Retrieving directory listing...
2012-03-29 16:54:04 1332 3 Trace: CFtpControlSocket::ChangeDirSend()
2012-03-29 16:54:04 1332 3 Command: PWD
2012-03-29 16:54:04 1332 3 Response: 257 "/" is current directory.
2012-03-29 16:54:04 1332 3 Trace: CFtpControlSocket::ParseSubcommandResult(0)
2012-03-29 16:54:04 1332 3 Trace: CFtpControlSocket::ListSubcommandResult()
2012-03-29 16:54:04 1332 3 Trace: state = 1
2012-03-29 16:54:04 1332 3 Trace: CFtpControlSocket::TransferSend()
2012-03-29 16:54:04 1332 3 Command: TYPE I
2012-03-29 16:54:04 1332 3 Response: 200 Type set to I.
2012-03-29 16:54:04 1332 3 Trace: CFtpControlSocket::TransferParseResponse()
2012-03-29 16:54:04 1332 3 Trace: code = 2
2012-03-29 16:54:04 1332 3 Trace: state = 2
2012-03-29 16:54:04 1332 3 Command: PASV
2012-03-29 16:54:04 1332 3 Response: 227 Entering Passive Mode (203,117,223,68,193,84).
2012-03-29 16:54:04 1332 3 Trace: state = 4
2012-03-29 16:54:04 1332 3 Command: LIST
2012-03-29 16:54:04 1332 3 Response: 150 Opening BINARY mode data connection.
2012-03-29 16:54:04 1332 3 Trace: code = 1
2012-03-29 16:54:04 1332 3 Trace: state = 5
2012-03-29 16:54:04 1332 3 Trace: CTransferSocket::OnConnect
2012-03-29 16:54:04 1332 3 Trace: CTlsSocket::Handshake()
2012-03-29 16:54:04 1332 3 Trace: Trying to resume existing TLS session.
2012-03-29 16:54:04 1332 3 Trace: CTlsSocket::ContinueHandshake()
2012-03-29 16:54:04 1332 3 Trace: CTlsSocket::OnSend()
2012-03-29 16:54:04 1332 3 Trace: TLS Handshake successful
2012-03-29 16:54:04 1332 3 Trace: TLS Session resumed
2012-03-29 16:54:04 1332 3 Trace: Cipher: AES-128-CBC, MAC: SHA1
2012-03-29 16:54:05 1332 3 Trace: CTlsSocket::OnRead()
2012-03-29 16:54:05 1332 3 Trace: CTransferSocket::OnReceive(), m_transferMode=0
2012-03-29 16:54:05 1332 3 Trace: CTlsSocket::OnSocketEvent(): close event received
2012-03-29 16:54:05 1332 3 Trace: CTransferSocket::TransferEnd(1)
2012-03-29 16:54:05 1332 3 Trace: CFtpControlSocket::OnReceive()
2012-03-29 16:54:05 1332 3 Response: 226-Directory has 32,035,041,280 bytes of disk space available.
2012-03-29 16:54:05 1332 3 Response: 226 Transfer complete.
2012-03-29 16:54:05 1332 3 Trace: CFtpControlSocket::TransferParseResponse()
2012-03-29 16:54:05 1332 3 Trace: code = 2
2012-03-29 16:54:05 1332 3 Trace: state = 5
2012-03-29 16:54:05 1332 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-29 16:54:05 1332 3 Trace: CFtpControlSocket::TransferSend()
2012-03-29 16:54:05 1332 3 Trace: state = 8
2012-03-29 16:54:05 1332 3 Trace: CFtpControlSocket::TransferEnd()
2012-03-29 16:54:05 1332 3 Trace: CFtpControlSocket::ResetOperation(0)
2012-03-29 16:54:05 1332 3 Trace: CControlSocket::ResetOperation(0)
2012-03-29 16:54:05 1332 3 Trace: CFtpControlSocket::ParseSubcommandResult(0)
2012-03-29 16:54:05 1332 3 Trace: CFtpControlSocket::ListSubcommandResult()
2012-03-29 16:54:05 1332 3 Trace: state = 3
2012-03-29 16:54:05 1332 3 Trace: CFtpControlSocket::ListSend()
2012-03-29 16:54:05 1332 3 Trace: state = 4
2012-03-29 16:54:05 1332 3 Status: Calculating timezone offset of server...
2012-03-29 16:54:05 1332 3 Command: MDTM FTP_test_anjan.txt
2012-03-29 16:54:05 1332 3 Response: 213 20120328023320
2012-03-29 16:54:05 1332 3 Trace: CFtpControlSocket::ListParseResponse()
2012-03-29 16:54:05 1332 3 Status: Timezone offsets: Server: 28800 seconds. Local: 28800 seconds. Difference: 0 seconds.
2012-03-29 16:54:05 1332 3 Status: Directory listing successful
2012-03-29 16:54:05 1332 3 Trace: CFileZillaEnginePrivate::ResetOperation(0)
2012-03-29 16:56:13 1332 3 Trace: CTlsSocket::OnSocketEvent(): close event received
2012-03-29 16:56:13 1332 3 Trace: CRealControlSocket::OnClose(0)
2012-03-29 16:56:13 1332 3 Error: Connection closed by server
2012-03-29 16:56:13 1332 3 Trace: CControlSocket::DoClose(64)
2012-03-29 16:56:13 1332 3 Trace: CFtpControlSocket::ResetOperation(66)
2012-03-29 16:56:13 1332 3 Trace: CControlSocket::ResetOperation(66)
2012-03-29 16:56:13 1332 3 Trace: CFileZillaEnginePrivate::ResetOperation(66)
2012-03-29 16:57:01 1332 3 Trace: CFileZillaEnginePrivate::ResetOperation(34)
2012-03-29 16:57:01 1332 3 Trace: CControlSocket::DoClose(64)
2012-03-29 16:57:01 1332 3 Status: Connecting to 203.117.223.68:21...
2012-03-29 16:57:02 1332 3 Status: Connection established, waiting for welcome message...
2012-03-29 16:57:02 1332 3 Trace: CFtpControlSocket::OnReceive()
2012-03-29 16:57:02 1332 3 Response: 220 Microsoft FTP Service
2012-03-29 16:57:02 1332 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-29 16:57:02 1332 3 Command: AUTH TLS
2012-03-29 16:57:02 1332 3 Response: 234 AUTH command ok. Expecting TLS Negotiation.
2012-03-29 16:57:02 1332 3 Status: Initializing TLS...
2012-03-29 16:57:02 1332 3 Trace: CTlsSocket::Handshake()
2012-03-29 16:57:02 1332 3 Trace: CTlsSocket::ContinueHandshake()
2012-03-29 16:57:02 1332 3 Trace: CTlsSocket::OnSend()
2012-03-29 16:57:02 1332 3 Trace: CTlsSocket::OnRead()
2012-03-29 16:57:03 1332 3 Trace: CTlsSocket::OnRead()
2012-03-29 16:57:03 1332 3 Trace: CTlsSocket::ContinueHandshake()
2012-03-29 16:57:03 1332 3 Trace: TLS Handshake successful
2012-03-29 16:57:03 1332 3 Trace: Cipher: AES-128-CBC, MAC: SHA1
2012-03-29 16:57:03 1332 3 Status: Verifying certificate...
2012-03-29 16:57:03 1332 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-29 16:57:03 1332 3 Command: USER SESAMiFTPSQA
2012-03-29 16:57:03 1332 3 Status: TLS/SSL connection established.
2012-03-29 16:57:03 1332 3 Trace: CFtpControlSocket::OnReceive()
2012-03-29 16:57:03 1332 3 Response: 331 Password required for SESAMiFTPSQA.
2012-03-29 16:57:03 1332 3 Command: PASS ********
2012-03-29 16:57:03 1332 3 Response: 230-Directory has 32,034,775,040 bytes of disk space available.
2012-03-29 16:57:03 1332 3 Response: 230 User logged in.
2012-03-29 16:57:03 1332 3 Command: OPTS UTF8 ON
2012-03-29 16:57:03 1332 3 Response: 200 OPTS UTF8 command successful - UTF8 encoding now ON.
2012-03-29 16:57:03 1332 3 Command: PBSZ 0
2012-03-29 16:57:04 1332 3 Trace: CTlsSocket::OnRead()
2012-03-29 16:57:04 1332 3 Trace: CFtpControlSocket::OnReceive()
2012-03-29 16:57:04 1332 3 Response: 200 PBSZ command successful.
2012-03-29 16:57:04 1332 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-29 16:57:04 1332 3 Command: PROT P
2012-03-29 16:57:04 1332 3 Response: 200 PROT command successful.
2012-03-29 16:57:04 1332 3 Status: Connected
2012-03-29 16:57:04 1332 3 Trace: CFtpControlSocket::ResetOperation(0)
2012-03-29 16:57:04 1332 3 Trace: CControlSocket::ResetOperation(0)
2012-03-29 16:57:04 1332 3 Trace: CFileZillaEnginePrivate::ResetOperation(0)
2012-03-29 16:57:04 1332 3 Status: Retrieving directory listing...
2012-03-29 16:57:04 1332 3 Trace: CFtpControlSocket::ChangeDirSend()
2012-03-29 16:57:04 1332 3 Command: CWD /
2012-03-29 16:57:04 1332 3 Response: 250 CWD command successful.
2012-03-29 16:57:04 1332 3 Command: PWD
2012-03-29 16:57:04 1332 3 Response: 257 "/" is current directory.
2012-03-29 16:57:04 1332 3 Command: CWD out
2012-03-29 16:57:04 1332 3 Response: 257 "/out" is current directory.
2012-03-29 16:57:04 1332 3 Trace: CFtpControlSocket::ParseSubcommandResult(0)
2012-03-29 16:57:04 1332 3 Trace: CFtpControlSocket::ListSubcommandResult()
2012-03-29 16:57:04 1332 3 Trace: state = 1
2012-03-29 16:57:04 1332 3 Trace: CFtpControlSocket::TransferSend()
2012-03-29 16:57:04 1332 3 Command: TYPE I
2012-03-29 16:57:04 1332 3 Response: 200 Type set to I.
2012-03-29 16:57:04 1332 3 Trace: CFtpControlSocket::TransferParseResponse()
2012-03-29 16:57:04 1332 3 Trace: code = 2
2012-03-29 16:57:04 1332 3 Trace: state = 2
2012-03-29 16:57:04 1332 3 Command: PASV
2012-03-29 16:57:04 1332 3 Response: 227 Entering Passive Mode (203,117,223,68,193,85).
2012-03-29 16:57:04 1332 3 Trace: state = 4
2012-03-29 16:57:04 1332 3 Command: LIST
2012-03-29 16:57:05 1332 3 Trace: CTlsSocket::OnRead()
2012-03-29 16:57:05 1332 3 Trace: CFtpControlSocket::OnReceive()
2012-03-29 16:57:05 1332 3 Response: 150 Opening BINARY mode data connection.
2012-03-29 16:57:05 1332 3 Trace: CFtpControlSocket::TransferParseResponse()
2012-03-29 16:57:05 1332 3 Trace: code = 1
2012-03-29 16:57:05 1332 3 Trace: state = 4
2012-03-29 16:57:05 1332 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-29 16:57:05 1332 3 Trace: CFtpControlSocket::TransferSend()
2012-03-29 16:57:05 1332 3 Trace: state = 5
2012-03-29 16:57:05 1332 3 Trace: CTransferSocket::OnConnect
2012-03-29 16:57:05 1332 3 Trace: CTlsSocket::Handshake()
2012-03-29 16:57:05 1332 3 Trace: Trying to resume existing TLS session.
2012-03-29 16:57:05 1332 3 Trace: CTlsSocket::ContinueHandshake()
2012-03-29 16:57:05 1332 3 Trace: CTlsSocket::OnSend()
2012-03-29 16:57:05 1332 3 Trace: TLS Handshake successful
2012-03-29 16:57:05 1332 3 Trace: TLS Session resumed
2012-03-29 16:57:05 1332 3 Trace: Cipher: AES-128-CBC, MAC: SHA1
2012-03-29 16:57:05 1332 3 Response: 226-Directory has 32,034,775,040 bytes of disk space available.
2012-03-29 16:57:05 1332 3 Response: 226 Transfer complete.
2012-03-29 16:57:05 1332 3 Trace: code = 2
2012-03-29 16:57:05 1332 3 Trace: state = 8
2012-03-29 16:57:05 1332 3 Trace: CTlsSocket::OnSocketEvent(): pending data, postponing close event
2012-03-29 16:57:05 1332 3 Trace: CTransferSocket::OnReceive(), m_transferMode=0
2012-03-29 16:57:05 1332 3 Trace: CTransferSocket::TransferEnd(1)
2012-03-29 16:57:05 1332 3 Trace: CFtpControlSocket::TransferEnd()
2012-03-29 16:57:05 1332 3 Trace: CFtpControlSocket::ResetOperation(0)
2012-03-29 16:57:05 1332 3 Trace: CControlSocket::ResetOperation(0)
2012-03-29 16:57:05 1332 3 Trace: CFtpControlSocket::ParseSubcommandResult(0)
2012-03-29 16:57:05 1332 3 Trace: CFtpControlSocket::ListSubcommandResult()
2012-03-29 16:57:05 1332 3 Trace: state = 3
2012-03-29 16:57:05 1332 3 Status: Directory listing successful
2012-03-29 16:57:05 1332 3 Trace: CFileZillaEnginePrivate::ResetOperation(0)
2012-03-29 16:57:07 1332 3 Trace: CControlSocket::DoClose(64)
2012-03-29 16:57:07 1332 3 Trace: CFtpControlSocket::ResetOperation(66)
2012-03-29 16:57:07 1332 3 Trace: CControlSocket::ResetOperation(66)
2012-03-29 16:57:07 1332 3 Trace: CFileZillaEnginePrivate::ResetOperation(66)
You are using passive mode with Filezilla, while active mode with WinSCP. Please post a log file from Filezilla with active mode.
Mujahed Hussain
Hi Martin,
I have changed the connection type to Active and tried but it shows the same error. Could not retrive directory listing. Appriciate your kind help.
2012-03-30 10:55:36 3224 3 Status: Connecting to 203.117.223.68:21...
2012-03-30 10:55:36 3224 3 Status: Connection established, waiting for welcome message...
2012-03-30 10:55:36 3224 3 Trace: CFtpControlSocket::OnReceive()
2012-03-30 10:55:36 3224 3 Response: 220 Microsoft FTP Service
2012-03-30 10:55:36 3224 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-30 10:55:36 3224 3 Command: AUTH TLS
2012-03-30 10:55:36 3224 3 Response: 234 AUTH command ok. Expecting TLS Negotiation.
2012-03-30 10:55:36 3224 3 Status: Initializing TLS...
2012-03-30 10:55:36 3224 3 Trace: CTlsSocket::Handshake()
2012-03-30 10:55:36 3224 3 Trace: CTlsSocket::ContinueHandshake()
2012-03-30 10:55:36 3224 3 Trace: CTlsSocket::OnSend()
2012-03-30 10:55:36 3224 3 Trace: CTlsSocket::OnRead()
2012-03-30 10:55:37 3224 3 Trace: CTlsSocket::OnRead()
2012-03-30 10:55:37 3224 3 Trace: CTlsSocket::ContinueHandshake()
2012-03-30 10:55:37 3224 3 Trace: TLS Handshake successful
2012-03-30 10:55:37 3224 3 Trace: Cipher: AES-128-CBC, MAC: SHA1
2012-03-30 10:55:37 3224 3 Status: Verifying certificate...
2012-03-30 10:55:37 3224 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-30 10:55:37 3224 3 Command: USER SESAMiFTPSQA
2012-03-30 10:55:37 3224 3 Status: TLS/SSL connection established.
2012-03-30 10:55:37 3224 3 Trace: CFtpControlSocket::OnReceive()
2012-03-30 10:55:37 3224 3 Response: 331 Password required for SESAMiFTPSQA.
2012-03-30 10:55:37 3224 3 Command: PASS ********
2012-03-30 10:55:37 3224 3 Response: 230-Directory has 32,033,722,368 bytes of disk space available.
2012-03-30 10:55:37 3224 3 Response: 230 User logged in.
2012-03-30 10:55:37 3224 3 Command: SYST
2012-03-30 10:55:37 3224 3 Response: 215 Windows_NT
2012-03-30 10:55:37 3224 3 Command: FEAT
2012-03-30 10:55:37 3224 3 Response: 211-Extended features supported:
2012-03-30 10:55:37 3224 3 Response: LANG EN*
2012-03-30 10:55:37 3224 3 Response: UTF8
2012-03-30 10:55:37 3224 3 Response: AUTH TLS;TLS-C;SSL;TLS-P;
2012-03-30 10:55:37 3224 3 Response: PBSZ
2012-03-30 10:55:37 3224 3 Response: PROT C;P;
2012-03-30 10:55:37 3224 3 Response: CCC
2012-03-30 10:55:37 3224 3 Response: HOST
2012-03-30 10:55:37 3224 3 Response: SIZE
2012-03-30 10:55:37 3224 3 Response: MDTM
2012-03-30 10:55:37 3224 3 Response: REST STREAM
2012-03-30 10:55:37 3224 3 Response: 211 END
2012-03-30 10:55:37 3224 3 Command: OPTS UTF8 ON
2012-03-30 10:55:38 3224 3 Trace: CTlsSocket::OnRead()
2012-03-30 10:55:38 3224 3 Trace: CFtpControlSocket::OnReceive()
2012-03-30 10:55:38 3224 3 Response: 200 OPTS UTF8 command successful - UTF8 encoding now ON.
2012-03-30 10:55:38 3224 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-30 10:55:38 3224 3 Command: PBSZ 0
2012-03-30 10:55:38 3224 3 Response: 200 PBSZ command successful.
2012-03-30 10:55:38 3224 3 Command: PROT P
2012-03-30 10:55:38 3224 3 Response: 200 PROT command successful.
2012-03-30 10:55:38 3224 3 Status: Connected
2012-03-30 10:55:38 3224 3 Trace: CFtpControlSocket::ResetOperation(0)
2012-03-30 10:55:38 3224 3 Trace: CControlSocket::ResetOperation(0)
2012-03-30 10:55:38 3224 3 Trace: CFileZillaEnginePrivate::ResetOperation(0)
2012-03-30 10:55:38 3224 3 Status: Retrieving directory listing...
2012-03-30 10:55:38 3224 3 Trace: CFtpControlSocket::ChangeDirSend()
2012-03-30 10:55:38 3224 3 Command: PWD
2012-03-30 10:55:38 3224 3 Response: 257 "/" is current directory.
2012-03-30 10:55:38 3224 3 Trace: CFtpControlSocket::ParseSubcommandResult(0)
2012-03-30 10:55:38 3224 3 Trace: CFtpControlSocket::ListSubcommandResult()
2012-03-30 10:55:38 3224 3 Trace: state = 1
2012-03-30 10:55:38 3224 3 Trace: CFtpControlSocket::TransferSend()
2012-03-30 10:55:38 3224 3 Command: TYPE I
2012-03-30 10:55:38 3224 3 Response: 200 Type set to I.
2012-03-30 10:55:38 3224 3 Trace: CFtpControlSocket::TransferParseResponse()
2012-03-30 10:55:38 3224 3 Trace: code = 2
2012-03-30 10:55:38 3224 3 Trace: state = 2
2012-03-30 10:55:38 3224 3 Command: PORT 192,168,43,197,14,89
2012-03-30 10:55:38 3224 3 Response: 501 Server cannot accept argument.
2012-03-30 10:55:38 3224 3 Trace: code = 5
2012-03-30 10:55:38 3224 3 Command: PASV
2012-03-30 10:55:38 3224 3 Response: 227 Entering Passive Mode (203,117,223,68,193,188).
2012-03-30 10:55:38 3224 3 Trace: state = 4
2012-03-30 10:55:38 3224 3 Command: LIST
2012-03-30 10:55:39 3224 3 Trace: CTlsSocket::OnRead()
2012-03-30 10:55:39 3224 3 Trace: CFtpControlSocket::OnReceive()
2012-03-30 10:55:39 3224 3 Response: 150 Opening BINARY mode data connection.
2012-03-30 10:55:39 3224 3 Trace: CFtpControlSocket::TransferParseResponse()
2012-03-30 10:55:39 3224 3 Trace: code = 1
2012-03-30 10:55:39 3224 3 Trace: state = 4
2012-03-30 10:55:39 3224 3 Trace: CFtpControlSocket::SendNextCommand()
2012-03-30 10:55:39 3224 3 Trace: CFtpControlSocket::TransferSend()
2012-03-30 10:55:39 3224 3 Trace: state = 5
2012-03-30 10:55:59 3224 3 Error: Connection timed out
2012-03-30 10:55:59 3224 3 Trace: CControlSocket::DoClose(2050)
2012-03-30 10:55:59 3224 3 Trace: CFtpControlSocket::ResetOperation(2114)
2012-03-30 10:55:59 3224 3 Trace: CControlSocket::ResetOperation(2114)
2012-03-30 10:55:59 3224 3 Error: Failed to retrieve directory listing
2012-03-30 10:55:59 3224 3 Trace: CFileZillaEnginePrivate::ResetOperation(2114)
2012-03-30 10:56:14 3224 3 Trace: CControlSocket::DoClose(64)
Regards
Hussain
Ok, so you probably need to use passive mode.
