Topic ".NET assembly wrapper class"
Priti
Ok Back to Square one!!! I asked this question almost a month ago and had to switch for not using .net dll...but I need to use it and for some reason the following code runs fine on local server, but not on Production Server???? It gives Time-Out Exception?? What is the problem? Its not registering the Ssh Servers Host key in cache through the code even though I am hard coding it. Please help.
Dim iALPS_SessionOptions As New WinSCP.SessionOptions()
With iALPS_SessionOptions
.Protocol = Protocol.Sftp
.HostName = Machine.ToString
.UserName = UserID.ToString
.Password = Password.ToString
.SshHostKey = UnixSshHostKey.ToString
End With
Try
Using iALPS_Session As New WinSCP.Session
Try
iALPS_Session.Open(iALPS_SessionOptions)
Catch ex As Exception
Response.Write(ex.ToString())
End Try
Priti
But it does work on Production Server with the following code though:
Dim SftpProcess As Process = New Process()
Dim UserOpenSessionString = "open sftp://" & UserID.ToString & ":" & Password.ToString & "@" & Machine.ToString _
& " -hostkey=" & Chr(34) & UnixSshHostKey.ToString & Chr(34)
With SftpProcess.StartInfo
.FileName = WinSCPFileName
.UseShellExecute = False
.RedirectStandardInput = True
'.RedirectStandardOutput = True
.CreateNoWindow = True
End With
SftpProcess.Start()
Priti
Try
End With
Try
SftpProcess.Start()
Response.Write(ex.ToString)
End Try
With SftpProcess.StandardInput
.WriteLine(UserOpenSessionString)
.WriteLine(ShellScript)
.WriteLine("exit")
.Close()
End With
Please, set Session.DebugLogPath and Session.SessionLogPath and post or email me the logs.
