Topic "Layout problems in "Find Files" dialog"
hpstoerr
If I open the "find files" dialog the buttons and the scrollbar are not visible at the right side (see attachment) and is thus effectively unusable. It stays that way, no matter how I resize the window. I suppose this happens since I raised the DPI setting to 125%. I'm using WinSCP 4.3.7 with Windows 7.
Description: Screenshot of the "find files" dialog (German)
Thanks for your post.
http://winscp.net/tracker/show_bug.cgi?id=831
foxyshadis
I see that high DPI works great in the latest version. Thanks! But in order to get it to work, I have to disable DPI virtualization on the exe via compatibility properties, because there's no DPI-aware manifest embedded or call to SetProcessDPIAware(). Can you do this so people don't have to tweak the compatibility properties?
Thanks for your suggestion.
Can you send me an email, so I can send you back a dev version of WinSCP for testing, once I implement your suggestion? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
Tiberius
Sorry to bump this thread, but I just installed 5.1.7 and as far as I can tell WinSCP still doesn't manifest itself as DPI aware - on my high-DPI (150%) devices, it gets scaled by the system instead of being crisp, even though the linked bug is shown as resolved. Is there a bug tracking this work? Thanks.
Try the latest beta version:
http://winscp.net/eng/docs/history#5.2.4
