Topic "Incompatible External Console Protocol Version 4"
christopher3683
Hi
I have installed Winscp 4.3.7, but i have used 5.0.6
(dll), in my coding i disabled version check like this session.disableVersionCheck=true;
after this i wanted to open this session, this time i got this error on this line "Incompatible External Console Protocol Version 4"
session.Open();
Please tell me the solutions
The only WinSCP version the assembly works with in 5.0.6 beta.
Can you send me that 5.0.6 Winscp version's exe or msi to my mail
my mail id is : christo83@gmail.com
You can download it from the same please, you have downloaded the assembly:
http://winscp.net/eng/download.php
Anonymeous
I was getting same error but it has been resolved by pick same version of both the file: WinSCP.exe & WinSCP.dll, because WinSCP.dll v1.0.0.528 is not compatible with WinSCP.exe v4.3.8 or v4.3.6, I am using WinSCP.exe v5.0.7.2268 which is compatible with dll v1.0.0.528.
Venkat
I am also getting same error with latest build.
winscp.dll File Version:1.1.0.3012/Product Version: 5.2.0.0
winscp.exe File Version:5.1.4.3020/Product Version: 5.1.4.0
Also not sure where to find compatible versions
I have released development version of the .NET assembly with 5.1.4 by mistake. Will fix it shortly. Meanwhile you can use 5.1.3.
Please download updated .NET assembly package (winscp514automation2.zip) from download page.
