Topic "Test support UTF8 file names via scp"
Here is link to test version support for file names UTF8 via SCP. I invite everyone to test it. Editing text in UTF8 is not done, but can be added later.
Before testing, make sure that you have made copies of all important files.
I am interested in all feedbacks about the proper or improper work, especially users from China and Japan. If testing will be successful, I will give to the author the source code, which he can used, including new versions of the program. Thanks for feedbacks.
Some remarks.
For testing copy this file in any directory. Don't delete any files of your WinSCP. Be sure that your remote supports unicode via SCP. Type in command line in Putty any national symbols and press enter. If you don't see them in answer, your remote does not support unicode and UTF8 in WinSCP via SCP is unavailable.
This works fine, could this be integrated to winscp main branch ?
