Topic "Command Line Options To Transfer Files "Simultaneously""
Shantanu
Hi Guys !
I have been unable to find out command line options that will help me transfer files from a folder in one server to another "SIMULTANEOUSLY". The operative word here is simultaneously, as I have had to chunk a huge file so that it goes through quickly. Is there a switch for the "transfer on the background by default". Help will be much appreciated.
Regards,
Shantanu
Paralel transfers are not supported by scripting. You can run multiple scripts in paralel though.
scriptWritter
hi
i want to transfer a file from my remote server
(<removed by admin>
file located in the path of remote machine as = /standalone/logs/) to my local machine path as c:/transferfile/
Kindly suggest the script if there is any.
Thanks in advance.
Please read documentation:
http://winscp.net/eng/docs/guide_automation
