Topic "Copying files to remote side failed."
rcaddy
I am using the portable executable to run this process in a script. I am only copying 1 file but it's name changes each time it needs to be copied. I have used both 4.3.7 and 5.0.6 beta and I get the same message "Copying files to remote side failed.". I have modified the settings in the script with and without "option transfer" and have set "option batch" to off and continue. In every case I still receive this message. I have also, renamed the file to be shorter and without numbers in the filename and get the same message. If I manually transfer the file through the GUI it transfers properly(both versions). I have included my command line, script, and the resulting log. Thank you for any help you may provide.
Command Line
C:\start\winscp.com /log=c:\start\log.txt /script=C:\start\wc.txt
Script
option echo on
option batch continue
option transfer ascii
open FTPSTrans
lcd \
put c:barcode*.* ./
close
Log
. 2012-04-03 09:59:34.891 --------------------------------------------------------------------------
. 2012-04-03 09:59:34.891 WinSCP Version 5.0.6 (Build 2074) (OS 5.1.2600 Service Pack 3)
. 2012-04-03 09:59:34.891 Configuration: C:\start\WinSCP.ini
. 2012-04-03 09:59:34.891 Local account: FRED\Rod Caddy
. 2012-04-03 09:59:34.891 Login time: Tuesday, April 03, 2012 9:59:34 AM
. 2012-04-03 09:59:34.891 Session name: FTPSTrans (Stored session)
. 2012-04-03 09:59:34.891 Host name: "link remove" (Port: 21)
. 2012-04-03 09:59:34.891 User name: ftpuseraccount@transconweb.com (Password: Yes, Key file: No)
. 2012-04-03 09:59:34.891 Tunnel: No
. 2012-04-03 09:59:34.891 Transfer Protocol: FTP
. 2012-04-03 09:59:34.891 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2012-04-03 09:59:34.891 Proxy: none
. 2012-04-03 09:59:34.891 FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: No]
. 2012-04-03 09:59:34.891 Local directory: C:\, Remote directory: /, Update: Yes, Cache: Yes
. 2012-04-03 09:59:34.907 Cache directory changes: Yes, Permanent: Yes
. 2012-04-03 09:59:34.907 DST mode: 1
. 2012-04-03 09:59:34.907 --------------------------------------------------------------------------
. 2012-04-03 09:59:34.907 Connecting to "link remove" ...
. 2012-04-03 09:59:34.954 Connected with "link remove", negotiating SSL connection...
< 2012-04-03 09:59:34.985 220 KTComputing FTP Server.
> 2012-04-03 09:59:34.985 AUTH TLS
< 2012-04-03 09:59:35.391 234 Using authentication type TLS
. 2012-04-03 09:59:35.673 SSL connection established. Waiting for welcome message...
> 2012-04-03 09:59:35.673 USER ftpuseraccount@transconweb.com
< 2012-04-03 09:59:35.704 331 Password required for ftpuseraccount@transconweb.com
> 2012-04-03 09:59:35.704 PASS *************
< 2012-04-03 09:59:35.735 230 Logged on
> 2012-04-03 09:59:35.735 SYST
< 2012-04-03 09:59:35.766 215 UNIX emulated by FileZilla
> 2012-04-03 09:59:35.766 FEAT
< 2012-04-03 09:59:35.798 211-Features:
< 2012-04-03 09:59:35.798 MDTM
< 2012-04-03 09:59:35.798 REST STREAM
< 2012-04-03 09:59:35.798 SIZE
< 2012-04-03 09:59:35.798 MODE Z
< 2012-04-03 09:59:35.798 MLST type*;size*;modify*;
< 2012-04-03 09:59:35.798 MLSD
< 2012-04-03 09:59:35.798 AUTH SSL
< 2012-04-03 09:59:35.798 AUTH TLS
< 2012-04-03 09:59:35.798 PROT
< 2012-04-03 09:59:35.798 PBSZ
< 2012-04-03 09:59:35.813 UTF8
< 2012-04-03 09:59:35.813 CLNT
< 2012-04-03 09:59:35.813 MFMT
< 2012-04-03 09:59:35.813 211 End
> 2012-04-03 09:59:35.813 PBSZ 0
< 2012-04-03 09:59:35.829 200 PBSZ=0
> 2012-04-03 09:59:35.829 PROT P
< 2012-04-03 09:59:35.860 200 Protection level set to P
. 2012-04-03 09:59:35.860 Connected
. 2012-04-03 09:59:35.860 --------------------------------------------------------------------------
. 2012-04-03 09:59:35.860 Using FTP protocol.
. 2012-04-03 09:59:35.860 Doing startup conversation with host.
> 2012-04-03 09:59:35.860 PWD
< 2012-04-03 09:59:35.891 257 "/" is current directory.
. 2012-04-03 09:59:35.891 Changing directory to "/".
> 2012-04-03 09:59:35.891 CWD /
< 2012-04-03 09:59:35.923 250 CWD successful. "/" is current directory.
. 2012-04-03 09:59:35.923 Getting current directory name.
> 2012-04-03 09:59:35.923 PWD
< 2012-04-03 09:59:35.954 257 "/" is current directory.
. 2012-04-03 09:59:35.954 Startup conversation with host finished.
< 2012-04-03 09:59:35.969 Script: Active session: [1] FTPSTrans
> 2012-04-03 09:59:35.969 Script: lcd \
< 2012-04-03 09:59:35.969 Script: lcd \
< 2012-04-03 09:59:35.969 Script: C:\
> 2012-04-03 09:59:35.969 Script: put c:barcode*.* ./
< 2012-04-03 09:59:35.969 Script: put c:barcode*.* ./
. 2012-04-03 09:59:35.969 Copying 1 files/directories to remote directory "./"
. 2012-04-03 09:59:35.969 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2012-04-03 09:59:35.969 TM: A; ClAr: No; CPS: 0; InclM:
. 2012-04-03 09:59:35.969 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2012-04-03 09:59:35.969 File: "c:BARCODE020912220507_.CSV"
. 2012-04-03 09:59:35.969 Copying "c:BARCODE020912220507_.CSV" to remote directory started.
. 2012-04-03 09:59:35.969 Ascii transfer mode selected.
. 2012-04-03 09:59:35.969 Starting upload of c:BARCODE020912220507_.CSV
> 2012-04-03 09:59:35.969 TYPE A
< 2012-04-03 09:59:36.001 200 Type set to A
> 2012-04-03 09:59:36.001 PASV
< 2012-04-03 09:59:36.032 227 Entering Passive Mode (216,172,99,164,212,75)
> 2012-04-03 09:59:36.032 LIST
< 2012-04-03 09:59:36.079 150 Connection accepted
< 2012-04-03 09:59:36.126 226 Transfer OK
. 2012-04-03 09:59:36.126 Copying files to remote side failed.
* 2012-04-03 09:59:36.126 (ExtException) Copying files to remote side failed.
* 2012-04-03 09:59:36.126 Transfer OK
. 2012-04-03 09:59:36.126 Asking user:
. 2012-04-03 09:59:36.126 Error transferring file 'c:BARCODE020912220507_.CSV'. ("Copying files to remote side failed.","Transfer OK")
* 2012-04-03 09:59:36.126 (EScpSkipFile) Error transferring file 'c:BARCODE020912220507_.CSV'.
* 2012-04-03 09:59:36.126 Copying files to remote side failed.
* 2012-04-03 09:59:36.141 Transfer OK
> 2012-04-03 09:59:36.141 Script: close
< 2012-04-03 09:59:36.141 Script: close
. 2012-04-03 09:59:36.141 Disconnected from server
Are you sure about the "c:barcode"? Try to use full path instead of relative one.
rcaddy
Martin,
I must apologize for taking up valuable time with this issue. I made an assumption that when I did the lcd \ command that I would not need the full path and as a result failed to even look at that as a possible issue. I learn something new every day. Thank you for your kind assistance.
Would be true, if C: is current drive. What is probably not in your case.
igabo
Command Line
Script
option echo on
open FTPSTrans
lcd \
put c:barcode*.* ./
close
Log
you try enable sftp in sshd_config
