Topic "Username with domain name will not work in batch"
WHB_BHS
I need to log in to an FTP server using a username that includes a domain name, but WinSCP is mis-interpreting the username. Without the domain name, I get the following after the password has been submitted from my script:
530 Subdomain not specified. Example username: acme/janet@example.com.
Connection failed.
Password prompt (no password provided or last login attempt failed)
When I add the domain name (using the above example), I get the following message:
Local directory: default, Remote directory: /janet@example.com:password@IP addrees, Update: No, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
DST mode: 1
Username prompt (no username provided).
I can connect in interactive mode using the domain name, but batch does not like this. Can anyone help?
You have to escape the slash:
http://winscp.net/eng/docs/session_url
WHB_BHS
Thanks, that worked. I simply could not find that info when I was searching for an answer.
Guest-2
When I interactively run a script file, my FTP command works.
But when the script runs in batch it does not. Can anyone help?
Here is my script;
"c:\Program Files\WinSCP\winscp.com" SWMC-FTP-PDF /command "option batch continue" "option confirm off" "put e:\swmc\SWMC-Availability\consultProvidersPrt.cfm.pdf" "close" "exit"
What does it mean "runs in batch"?
Also make sure you open the session using "open" command.
Jerry123
What does it mean "runs in batch"? A Scheduled Task running .bat file
also make sure you open the session using "open" command. The Open command? This should be part of the stored session, SWMC-FTP-PDF correct?
Here's my issue; when I run a .bat file by double-clicking it, then WinSCP works perfectly within that script.
When I Schedule the .bat file to run, it runs, but the WinSCP part of the script is ignored/does not execute for some reason.
Can you help?
Do not open the session by passing stored session name on command line, use "open" command.
http://winscp.net/eng/docs/scriptcommand_open
http://winscp.net/eng/docs/guide_automation
Can you help?
Please read FAQ:
http://winscp.net/eng/docs/faq_scheduler
