Topic "Syncronize Vs GetFiles C#"
Andrezinn
Here I am, after try alot of different thinks, asking you guys if someone could please help me.
Today I have this script:
option batch on
open XXXX:YYYY@ZZZ.WWW.KKK.QQQ:7001
cd "ROOT"
synchronize local "J:\FILES" "/ROOT/Jan"
And I am trying to do this Syncronyze code, using C# as follow:
// Setup session options
Protocol = Protocol.Sftp,
HostName = Ip,
UserName = User,
Password = Pwd,
PortNumber = Convert.ToInt32(Port),
SshHostKey = "ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
//Desabilita o check de verses
session.DisableVersionCheck = true;
// Will continuously report progress of synchronization
session.FileTransferred += FileTransferred;
// Connect
session.Open(sessionOptions);
RemoteDirectoryInfo directory = session.ListDirectory(cEntrada[0]);
foreach (RemoteFileInfo fileInfo in directory.Files)
listBox1.Items.Add("Name: " + fileInfo.Name + " length:" + fileInfo.Length + " Permissions:" + fileInfo.FilePermissions + " Wrote in " + fileInfo.LastWriteTime);
// UNTIL HERE, IT IS OK!
//Arrow It suppose to work as we have in WinScp example:
SynchronizationResult synchronizationResult;
synchronizationResult = session.SynchronizeDirectories(SynchronizationMode.Local, cEntrada[0], cSaida[0], false);
synchronizationResult.Check();
// But Just didnt bring me anything.... Question
// In another hand, If I try
TransferOperationResult transferResult;
transferResult = session.GetFiles(cEntrada[0], cSaida[0], false);
transferResult.Check();
// It start to download my files... but I have more than 100 files day, and I really dont want to download all of then everytime.
Should be:
synchronizationResult = session.SynchronizeDirectories(SynchronizationMode.Local, cSaida[0], cEntrada[0], false);
Andrezinn
prikryl,
Than you for your help, but nothing happens... it still pass thru this line as if I dont have it
I also have my:
private static void FileTransferred(object sender, TransferEventArgs e)
And once again, my code never enter on it
Andrezinn
It was a stupid error in my path cSaida[0]. Rolling Eyes
cSaida[0] = "J:\Test\Files from Jan\Folder1"
and in Windows I had
"J:\Test\Files from Jan\"
Thank you!
Now I need to know how to capture these events by the "FileTransferred" as the link
http://winscp.net/eng/docs/library_session_synchronizedirectories#example
Let me know if you need any help with this.
Andrezinn
prikryl,
To be honest, It is working kind well. I just don't know how can I (if I can) watch my download % for each file, and\or my % of files download.
In this second case I tryed:
int contador = 0;
label1.Text = "Listing";
contador++;
progressBar1.Maximum = contador;
and in my FileTransferred Method
progressBar1.Value++;
But it just work for the first Path (Of course, I couldnt retrieve my subfolders... since I start my session.SynchronizeDirectories, it freeze my code)
Could you help me with it?
With synchroniztion there's no way to calculate progress. WinSCP does not accounce how many files it's going to synchronize.
