Topic "Run WinSCP on Windows Start / Sync Local & Remote Folder?"
AStaley
Is it possible to have Winscp run at Windows statup and auto-login with a pre-specified username/password? And then keep a local and a remote folder in sync without any user intervention? I can do it manually by using Commands>Keep Directory upto Date after I've connected to the server, but I can't seem to automate the process. All I am trying to archive is to keep the camera folder on a laptop in sync with a remote FTP server.
Thanks, AStaley.
AStaley
Thanks, AStaley.
Okay, posted to soon and without thinking. I've created a shortcut to WinSCP which I can put in to my startup folder to run WinSCP with a stored session, what I can't find in the documentation is how to have WinSCP start with specific Sync Options and minimized?
AStaley.
You can use /keepuptodate command-line parameter (to start GUI sync):
http://winscp.net/eng/docs/commandline
Or you can script it using keepuptodate command:
http://winscp.net/eng/docs/guide_automation
http://winscp.net/eng/docs/scriptcommand_keepuptodate
AStaley
Thanks for the reply.
I've got it doing what I need via a script. I have WinSCP minimized to the system tray monitoring a specific folder, and it just copies to a remote server when a change is made, nice and straight forward with no user intervention (love it). Unfortunately it's not good enough. Is there anyway to display a message on the screen when a successfull or failed file transfer has been made? Or even a baloon from the system tray?
Otherwise I am stuck making the transfer process manual so the users can see the file progression Sad
Thanks, AStaley.
This request has been added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=838
(Note that this relates to GUI, not scripting)
