Topic "Set default session not stored in ini"
I cannot get a default session to be stored in the ini storage file.
Using Windows WinSCP 4.3.7 and 5.0.6 beta portable.
-I create a new session, set connection/timeout to 60 and save the session
-I edit the session so that the settings are loaded
-I push the "Set defaults" button
-Then, when I push the "New button", the default settings are loaded OK
-When I close the program, restart it and then create a new session, everything is empty
The [Sessions\Default%20Settings] section is never created in the ini. If I add it manually, it works.
What I am doing wrong?
Thanks all.
Thanks for your post.
