Topic "Editor corrupts files in 5.0.6"
test43423
The text editor is inserting some bad characters or removing tabs because it messes up my source files to the point they won't run. It used to work fine.
thomase7
WINSCP's file editor occasionally corrupts files. If i open the corrupted files in another editor ( Notepad ++) the document has several "NUL" throughout. If i delete them and reupload they work fine.
what version of WinSCP are you using? What protocol?
test43423
Sorry, I don't want to download the debug version but note:
Does not occur in 4.3.7.
To recreate:
On an SFTP connection.
Right click an existing file and choose edit.
Edit the file.
Ctrl + S to save.
The file is now slightly corrupted some of the time.
Why? You do not need to use it on any sensitive files. Just use it on any test file.
