Topic "how can i get the SShKey from server ?"
deconett
halo,
i have a big problem :),namely, I write a C # program that scans a network and connect using WinSCP to several servers.to connect to this server, I need a SSHkey!!!
how can i get this SShKey from server ?
can i connect to the Server without SSH key?
Many thanks for your help
You should know it before connecting. Should be part of the info you get from the server admin, along with your credentials.
deconett
there exists a function with which I can get this infos from the server ? like winSCP does that.
when are the update with the event to implement custom way of verifying the host key coming? Smile
http://winscp.net/tracker/show_bug.cgi?id=815
No. That would spoil the purpose of key verification.
I cannot give any date yet.
Perhogan
I had the same problem today and I solved this way:
Assuming that i trust that the server that is at the address is reliable (it is an internal server in the network)
1) I purged the data saved in WinSCP from previous connections so it erases the saved key (under tools).
2) i reconnected to the sftp server, biung the 1st time WinSCP shows me the key and ask if I accept it anyway
3) At this point you see a message with the Key and there is a button to copy it Smile
problem solved Smile
You can also get the key on Server and Protocol Information Dialog:
http://winscp.net/eng/docs/ui_fsinfo
Perhogan
By the way.
Really good software and site.
Amazing you do all by yourself
thank you
I have added topic to the FAQ:
https://winscp.net/eng/docs/faq_hostkey
