Topic "What is "Transfer each file individually on background"?"
zespri
From documentation:
The Transfer each file individually on background by default checkbox makes WinSCP en-queue each selected file as separate transfer by default.
Can some one explain this to me please? The check box makes WinSCP en-queue each selected file as separate transfer, but as opposed to what?
Cheers!
If you select 5 files/directories and have this unchecked, you will get one entry in the queue. If you have this checked you will get 5 entries in the queue.
zespri
Ah, thanks. I wonder if it's possible to make this option work for folders as well, so that when you queue up a folder individual files are added to the queue.
