Topic "Cannot see existing file."
heineman.bob
I am trying to download a file from an ftp site using ftps with explicittls mode on. In filezilla I am able to see this file on the remote server but within the WinSCP GUI and command line scripting (using an ls) I cannot see the file I want to download. It doesn't have a recognizable extension as it is a custom file. I have updated my portable exe and com components to the most recent version and still no change. Am I missing an option?
Any help would be greatly appreciated.
What is the file name? Can you see other files in the directory?
heineman.bob
The file types are nonsense like .47v25jd3453kd and I can see the other folders in the directory I just cannot see any files with this unconventional name. But this extension changes. I have no control over the naming and I cannot add files to check if other files are visible from this destination but I do know that they are there because I can use a different application to see them and download them manually but the problem is that this is supposed to be an automated process. Any ideas?
Files starting with dot are considered hidden. Make sure you enable Show hidden files:
http://winscp.net/eng/docs/ui_pref_panels
Also some servers filter files starting with dot themselves.
heineman.bob
The files do not start with '.' that was just an example of the extension (ie.. 234k528j.47Nqjeu8) I have 'show hidden files' turned on.
Please post a complete log file both from WinSCP and Filezilla.
heineman.bob
These are file logs connecting to the same site using filezilla which can see 3 files and winscp which can see 0 files.
I had to block the ip / port / user name for privacy reasons but they are they same in each connection.
Thanks in advance!
filezilla.log (2.36 KB) [Download]
Description: (none)
heineman.bob
here is the winscp log
winscp.log (3.65 KB) [Download]
Description: (none)
heineman.bob
I have sent the trace log via email. Thanks.
heineman.bob
Prikryl,
That fixed my issue! Thank you for all your time and effort with getting this to work correctly. After setting the show hidden files to off I could see my files out on the ftp server. You have made many people happy with this. Thanks again.
Bob
P.S. Do you want those trace logs for each situation?
I'm glad it helped.
Yes please.
klonos
I'm having this issue with /usr/share/php/.channels directory. I have the "Show hidden files" option enabled. Perhaps this only works for files (for example I'm able to see .htaccess & .gitignore files) and not with directories?
Please attach a full log file showing the problem using the latest version of WinSCP.
