Topic "ACL Support"
FACL
Please add support to set ACL for files/directories and recursive.
The setfacl and getfacl command-line is terrible.
What protocol? What server do you use? Does your server even support it?
Yes it does. You can type getfacl/setfacl in bash
Protocols are all supported over SSH / Port 22.
But not the FTP/Port 21 ones..
OS: CentOS 6
I mean if your SFTP server supports it.
Because its SFTPv3 it is not supported over SFTP.
ProFTP has an ACL and SFTP6 module. Maybe it will work together.
But anyway it should be possible over a seperate SSH Session to manipulate ACL entries.
For ProFTP see:
SFTPv6 http://www.proftpd.org/docs/contrib/mod_sftp.html sftpProtocolVersion
The mod_sftp module supports SFTP protocol versions 1-6; using any other protocol versions will result in bad configuration.
FACL http://www.proftpd.org/docs/modules/mod_facl.html
OK. This request is tracked here:
http://winscp.net/tracker/show_bug.cgi?id=74
thanks
