Topic "Windows Scheduled task and script"
jasonplp
I'm new to FTP and WinSCP.. i want to create a script which will update a remote site automatically at a certain time each day.
I've written a text file called example1.txt with the following:
option batch abort
open ftp://user:password@domain
option transfer binary
cd \remote folder\
put \local folder\
close
Then i've created a windows scheduled task which is currently set to run winscp.exe at 13:00 each day, where do i add the command for it to run the text file so that it automatically updates the remote folder?
ok i've figured out where to put the code but now i have a related issue.
This will be a very basic question to most but if i'm wanting to upload all files from my local folder to the remote folder what's the right code?
is this correct...
cd \remote folder\
put \local folder\
or is it the other way round and 'put \remote folder' instead?
ignore that - a bit of research and i've sorted that issue out
