Topic "Execute WinSCP from a batch file"
Quickdeveloper
Hi
I want to execute winscp script from a batch file.
Assume the following contents are in C:\MYFILE.BAT
echo " OPENING THE SESSION "
winscp.com /console /command:"open xyz:abc@ipaddress"
echo "CONNECTED TO THE VM "
REM   delete old files
rm file1.tar
when i run C:\>MYFILE.BAT , i am able to connect to unix vm, however it goes into shell mode and second command (deleting file1.tar won't get executed). do we need to give any other parameter?
I know we can execute batchfile itself from winscp directory (eg: winscp.com /script:filename.bat) but in that case i can't check errors with if/ else conditions in batch file since winscp doesn't recognise the if/else.
Any suggestions please? i don't want to use xml logging as it looks too complicated for my use.
quickdeveloper
Please also note that i am using winscp.com to redirect the output to a text file.
The only other option would be to open a new winscp session in each command line of batch file which involves more cost.
You have to put WinSCP command to a separate script file.
Please read scripting guide:
http://winscp.net/eng/docs/guide_automation
quickdeveloper
Thanks Martin,i checked it.
I have used C# with WinSCP dll and accomplished the task.
I realized it's much easier and faster that way in terms of exception handling Very Happy
Thanks!
atchere
Question I am having trouble getting WINSCP to take a password in the batch mode what is the correct syntex to make this happen
atc
Prasadhello
I am trying to run winscp from bat file and with xp_cmdshell in sql server. However when I run it keeps running forever. I have put exit in bat file. Anybody aware of this issue?
Also is there any way to capture winscp dir results in sql server table or like normal result set instead of XML.
Please start a new thread and attach a full log file showing the problem (using the latest version of WinSCP).
To generate log file, use /log=path_to_log_file command-line argument. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
Mahmoud
Hi all,
I did the following batch file to send file to sftp server, but the put command (or any commands) after sftp session opeded didn't work:
cd C:\Program Files\prog1\output1
WinSCP.exe username@x.x.x.x/example/test
put %file%
close
can any one help?
thnaks
You are obviously combining Windows and WinSCP commands in a single file. You cannot do this.
Read http://winscp.net/eng/docs/guide_automation
Fairfielder
I don't understand. On the following page it shows this example batch file, which combines WinSCP and Windows commands:
Here's the example batch file:
winscp.com /script=example.txt
if %ERRORLEVEL% neq 0 goto error
echo Success
sendmail.exe -t < success_mail.txt
exit 0
:error
echo Error!
sendmail.exe -t < error_mail.txt
exit 1
There's no WinSCP command it that batch file. The WinSCP commands are in example.txt.
Madhu
Hi
I am trying to get file using SFTP. My set up was authentication with public key Passphrase.
Here is my scrip file name getfile.txt
open xxxxxx (site already stored with host name, port and username)
passphrase
get *.txt to c:\*.txt
Close
Created download.bat file as follows:
@echo off
winscp.com /script=getfile.txt
both the files are saved at WinSCP folder.
When download.bat file run, the script did not take Passphrase as per second line and come out without further execution.
Can anyone help how input Passphrase.
Madhu
Use the -passphrase switch:
open xxxxxx -passphrase=mypassphrase
See https://winscp.net/eng/docs/scriptcommand_open
Note that it is generally not recommended to use stored site in script.
See https://winscp.net/eng/docs/scripting#configuration
