Topic "Path mask: files in subfolders (beta vs stable)"
Using Windows WinSCP 4.3.7 and 5.0.6 beta portable on WindowsXP.
I would like to fetch all files matching "foo*.txt" in a certain folder, without getting matching files from subfolders.
get /folder/foo*.txt c:\temp\
Using both the stable and beta version, I get the same results and files matching "foo*.txt" in subfolder "/folder/subfolder/" are not returned. But the documentation, section "Path Mask" says the following:
For example mask /home/martinp/*.txt matches all text files within the directory and its subdirectories (in the latest beta release only).
Am I misunderstanding the doc?
Thank you.
After some additional tests I can't get the beta to match files in subdirectories using a path mask.
The documentation was wrong. I have fixed it. Basically there was not change in the beta regarding path masks.
