Topic "Editing Files were conected with FTP with Encryption"
Wadim
Hey,
i have the problem that i can't edit textfiles while im connected to my server, with other clients it works.
I'm connected with FTP and SSL Explicit encryption or with TLS Explicit encryption. It won't work with both.
the problem exists in version 4.3.7 and 5.0.6 beta.
bye wadim
What does it mean "i can't edit textfiles"? What happens? Any error message?
Wadim
I edit mit PHP-File and only the half of the file would be trasfered to the Server.
The file is not boken or any thing, but the content ist not complete --> and the code don't work. The content must be longer than 62 lines.
There are no error message.
Wadim
here is the log file.
at that running the file that was edited and transfered back to the server was complet emty. Rolling Eyes
winscp.log (16.3 KB) [Download]
Description: (none)
Thanks. Does it ever happen when you upload the file directly (not from editor)? Do you have access to server-side log?
Wadim
yes the problem exist too when i upload files with the ftp-client direktly
Mon May 07 15:56:52 2012 0 ::ffff:ip-adress 2633 fileroot/css/style.css a _ o r username ftps 0 * c //download
Mon May 07 15:57:31 2012 0 ::ffff:ip-adress 0 fileroot/css/style.css a _ i r username ftps 0 * c //upload
after that i fixed the file per ftp
Mon May 07 16:05:06 2012 0 ::ffff:ip-adress 0 fileroot/css/style.css a _ o r username ftp 0 * c //download
Mon May 07 16:05:15 2012 0 ::ffff:ip-adress 2647 fileroot/css/style.css a _ i r username ftp 0 * c //upload
Linda Kaioh
Hi! I'm not sure if it's same problem but looks like it is.
WinSCP version 5.0.7.2268 on Windows XP Prof SP3. Upgraded from 5.0.6.2074. Protocol is FTP. Using GUI in NC style.
I'm trying to edit text file from FTP server. Text file is in UTF-8 encoding with text in Russian. File name also contains cyrillic characters (server is FileZilla and it sends directory listing in UTF-8). I press F4 and wait for transfer to be completed. Then WinSCP shows internal editor. In this editor program shows only small part of file or in some cases niothing at all. In status bar it shows "UTF-8". When I switch to windows-1251 editor shows full text (not decoded).
So I think editor just incorectly decode UTF-8 text.
Wadim
Hey,
the problem is like you discribe that, but ohnly like Wink
i have no problems then ssl ist deaktvated. only then i using FTPS. same file, same editor.
Linda Kaioh
Sounds true. I have FTP connection with expicit encryption. Now I tested it without encryption and problem still there.
@Wadim: Do I understand right that your file is ok yet, when opened in an itnernal editor?
@Linda Kaioh: Please start new topic.
Wadim
the file is ok then i upload it without ssl...
the file is uploaded emty or onle a half then i use ssl...
it is equal where i edit the file...
(edit on the server or edit on the computer and upload it seperatly)
