Topic "Ignore "set mode" errors?"
RevBob
I frequently find myself uploading many files across multiple folders, several of which are owned by others but maintained by a small team (including myself). I also have my upload settings configured to set certain permissions, allowing full group/owner access to the files. This results in many spurious errors when WinSCP attempts to set permissions that are already in place...which can result in real errors getting buried.
Is there any way to suppress "false errors" of this nature without suppressing all errors?
I'd also like to be able to set the group for new files that I upload, but that's another issue...
Try to set Ignore permission errors:
https://winscp.net/eng/docs/ui_transfer_custom#upload_options
RevBob
That was the first thing I tried, but it ignored all permission errors - including serious cases where the permissions prohibited one of the files from uploading. So I'm left with either crossing my fingers and hoping everything went okay, or having to wade through a ton of bogus "set mode denied" errors just in case there's a "permission denied" mixed in there somewhere.
That should not be the case. Can you post a log file showing upload overwritting one file that you do not own with the Ignore permissions error turned on?
RevBob
First of all, please excuse my mistaken recollection; I've been living with this bug for a while now. Checking "Ignore permissions error" does not cause all "set mode" and "denied" errors to be suppressed. Rather, it does nothing either way; the "set mode" error comes through whether that box is checked or not, just as "denied" does.
RevBob
Log emailed.
[Edit: Please ignore the first version in favor of the shorter second log.]
