Topic "Different way to use WinSCP within SSIS using a Script task"
pturner
Must have WinSCP installed
run gacutil -i "C:\Program Files\WinSCP\WinSCP.dll" within the command prompt, as an admin
Within your SSIS Script task, add a reference to the dll file using the browse task
add using WinSCP;
your Main() method can now look similar like the following:
public void Main()
string strFTPPath = Dts.Variables["FTPFolderPath"].Value.ToString();
string strDestination = Dts.Variables["DestinationFolder"].Value.ToString();
bool fireAgain = false;
strFTPPath = strFTPPath + @"/";
Dts.Events.FireInformation(0, "FTP Path Used:", strFTPPath, "", 0, ref fireAgain);
Dts.Events.FireInformation(0, "Destination Path Used:", strDestination, "", 0, ref fireAgain);
try
// Setup session options
Protocol = Protocol.Sftp,
HostName = "FTP server",
UserName = "User",
Password = "Password",
SshHostKey = "ssh-rsa xxxx xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
// Connect
session.ExecutablePath = @"C:\Program Files\WinSCP\WinSCP.exe";
session.Open(sessionOptions);
// Upload files
TransferOptions transferOptions = new TransferOptions();
transferOptions.TransferMode = TransferMode.Binary;
TransferOperationResult transferResult;
//transferResult = session.PutFiles(@"d:\toupload\*", "/home/user/", false, transferOptions);
transferResult = session.GetFiles(strFTPPath, strDestination, false, null);
// Throw on any error
transferResult.Check();
// Print results to output box
foreach (TransferEventArgs transfer in transferResult.Transfers)
Dts.Events.FireInformation(0, "Files Uploaded:", "", "", 0, ref fireAgain);
session.Dispose();
//return 0;
catch (Exception e)
Dts.Events.FireInformation(0, "Error: ", e.Message.ToString(), "", 0, ref fireAgain);
Dts.TaskResult = (int)ScriptResults.Failure;
//return 1;
Dts.TaskResult = (int)ScriptResults.Success;
Thanks for sharing this.
Based on this example, I have created article on using the WinSCP .NET assembly from SSIS:
http://winscp.net/eng/docs/library_ssis
