Topic "TMP files are not being cleaned up after Session is closed"
gschmidt34
Every time a Session is opened a .tmp file is created in the c:\windows\temp directory, but these files are not getting removed when the Session is destroyed - even if explicitly called Session.dispose();
Is there an option for this? Or how should it be handled?
Thanks for your post.
http://winscp.net/tracker/show_bug.cgi?id=849
mobject
Any workaround for this please ? Currently my winscp exceeded 65535 temporary files and It crash.
mobject
gschmidt34
I downloaded the latest release and the issue appears to be resolved.
ted1001
I just downloaded the latest version.
tmp-files are not deleted after running dispose.
Winscp.exe 5.0.7.2268
Winscp.dll 5.0.7.0 (file version 1.0.0.528)
Old ones or new ones? The olds one are not. You need to delete them manually. But the new ones should be deleted.
ted1001
The new ones are not deleted. Triggering it from Powershell like this:
$sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
$sessionOptions.HostName = "---------REMOVED--------"
$sessionOptions.UserName = "---------REMOVED--------"
$sessionOptions.Password = "---------REMOVED--------"
$sessionOptions.SshHostKey = "ssh-rsa 1024 ---------REMOVED--------"
$session.ExecutablePath = $winscpPath
$session.DisableVersionCheck = "true"
Example of the content of a tmp-file not deleted:
<session xmlns="http://winscp.net/schema/session/1.0" name="---------REMOVED--------" start="2012-05-24T08:22:55.320Z">
<group name="open -hostkey=&quot;ssh-rsa 1024 ---------REMOVED--------&quot; -timeout=15 &quot;sftp://---------REMOVED--------5&quot;" start="2012-05-24T08:22:55.711Z">
</group>
<group name="stat -- &quot;./files/lmsdeploy/---------REMOVED--------/uploadcompleted.true&quot;" start="2012-05-24T08:22:55.758Z">
<stat>
<filename value="/files/lmsdeploy/Atlantic/uploadcompleted.true" />
<result success="false">
<message>Can't get attributes of file './files/lmsdeploy/Atlantic/uploadcompleted.true'.</message>
<message>No such file or directory.
Error code: 2
Error message from server: No such file
Request code: 7</message>
</result>
</stat>
<failure>
<message>Can't get attributes of file './files/lmsdeploy/---------REMOVED--------/uploadcompleted.true'.</message>
Error code: 2
</failure>
</group>
<group name="exit" start="2012-05-24T08:22:55.883Z">
</group>
</session>
I will contact you shortly.
I have sent you an email with a development version of WinSCP to address you have used to register on this forum.
gunnerit
So that how to resoled this problem. I also have this issue.
I create a service run on Win2k8 Server.
