Topic "session navigation using tabs"
yereverluvinunclebert
Win SCP has proven to be very configurable - the only feature I need which is missing from the current version of Win SCP is the session navigation using tabs. An option should be provided that allows open sessions to display in tabs, these are easy to navigate and it is obvious from a glance which sessions are open.
WinSCP 5.0.7 beta supports session tabs:
http://winscp.net/eng/docs/ui_sessiontabs
Sounds great Martin, I will wait until that version is stable and look forward to the functionality, are the tabs moveable so that I can position them in any desired location? I have been using wsFTP for so long that I like to be able to configure Winscp buttons in exactly the same positions as wsFTP.
I am very impressed with winscp, in particular the ability to encrypt usernames/passwords with a master password. I have had sites hacked by a filezilla exploit. Filezilla as you may know, stores its passwords in plain text in an unsecure location, I am no longer a fan of filezilla as a result. I have been searching for a while for a good open source ftp client with password security. WsFTP has the ability to encrypt passwords but does not use a unique encryption key supplied by the user so I always worry about the level of encryption it supplies... One of my main reasons for moving to another client.
We hope that the next release, 5.0.8, is stable.
Not yet. We plan this for 5.1.
If you have any more comments on WinSCP usability, please do not hesitate to make another posts. Were are very interested in any feedback.
Will do, thanks for the fast feedback, donation given.
Thanks for the donation!
franc
Thank you for the Session Tabs, this is the killer feature I had been waiting for.
Donated now too, at least Smile
Thank you too!
The tabs are very good functionality, a great improvement. Can I request that in the next version we have some tab close buttons as per firefox tabs. My preference is for a single close button 'x' on the far right hand of winscp, where it used to be on Firefox by default. Clicking on it closes the current tab.
Later versions of Firefox have the option of putting close buttons on each tab which I don't like, it reduces the amount of space for text.
Sute, we plan that.
http://winscp.net/tracker/show_bug.cgi?id=851
