Topic "PowerShell/.NET Assembly Error - Recursive calls not allowed"
ta0147896325
I receive a "Recursive calls not allowed" error connecting to a Cygwin/OpenSSH system via PowerShell/.NET assembly and issuing a Session.FileExists.
Any recommendation?
test3.zip (4.9 KB) [Download]
Description: (none)
Thanks for your post.
http://winscp.net/tracker/show_bug.cgi?id=852
I have documented workaround here:
http://winscp.net/eng/docs/library_session_fileexists
ta0147896325
Thank you for the fix. It works as expected.
Implemented in PowerShell as function at top of script:
function FileExistsFix
[WinSCP.Session]$pSession = $args[0]
[string]$pPath = $args[1]
try
$pSession.GetFileInfo($pPath)
return $TRUE
catch [$pSession.SessionRemoteException]
return $FALSE
And called within main script body as:
if (FileExistsFix $session $remotePath) {
Write-Host "Remote file exists."
else
Write-Host "Remote file does not exist."
I have sent you an email with a development version of WinSCP to address you have used to register on this forum.
ta0147896325
The fix within the development version works without error.
I am able to use the following and works in both cases:
if($session.FileExists($remotePath)) {
else
Thank you for all your work!
